Wondering if anyone knows if this is normal, I've tested the voltage outputs from my CAS and have found something that may be a problem.
The signal from the 1degree output is around 2.4 volts and sits quite steady at idle. But the 120degree signal seems very erratic, jumping between 0.9 to 1.6volts at idle.
Is this normal, or is my CAS U/S?
https://www.sau.com.au/forums/topic/155957-crank-angle-sensor/
Well with a bit of research I found the CAS test section in the stagea service manual
It says the 120 degree signal should be between 1.3v to 1.4v at idle, and I imagine it should be a reasonably steady reading aswell.
So it's looking as though mine is playing up.
Please sit down before reading this part.
A new item is worth $1042 from Nissan, what a joke that is.
Oh if anyone is kind enough, maybe they could test the voltage on their CAS so I can compare with mine.
I can supply ECU pin numbers, wire colours etc if needed.
I wanna know 100% for sure.
Let's just hope mine isn't playing up as well. I've been getting quite bad fuel consumption lately, and I've yet to pinpoint the problem due to my g/f's car being out of action. I'll let you know when she won't be using the car and you can go around and pull mine apart :laugh:
Cheers mate, only have to get to the ecu plug, to take a voltage reading.
DATS interesting Brendan. Now my shoulder is getting better I am going to try and solve my P. poor fuel consumption, so this could be an area to check.
It is quite interesting, I'm finding, I've realised it's much easier to find a problem with the right gear and a full service manual.
Talking about the right gear, i'm lucky enough to be able to borrow the ocilliscope from work, so I'll diagnose this sucker once and for all.
Ok, I've tested the output with the ocilliscope, and it looks fine compared to the service manual. Back to the drawing board.
One thing I noticed yesterday before I started it the voltage from the MAF was 0.9 volts, manual says 0.2 volts.
Didn't test it until after it was started today, and the voltage looked fine. Will have to test again tomorrow before startup.
This is really getting annoying.
Wont need to now, thanks for the offer though mate, much appreciated.
Working afternoon shift aswell, till 11pm, so wouldn't be able to make it.
I'm reasonably satisfied that the CAS is ok now, I'm looking at the MAF sensor now, will hopefully have an answer tomorrow.
I've been searching the forum, and it seems as though the issue i'm having is very common. And no one seems to have a definate answer.
So I'll keep prodding away, and will hopefully find something.
The CAS produces a pulsing signal when the engine is running, the 1 degree is stable because it is more frequent, hence the multimeter reading doesn't vary much. The 120 degree signal is less frequent hence the multimeter reading does vary.
As far as I know you can't check CAS operation with a multimeter at idle. The 120 degree signal should stabilse as the rpm rises. So maybe try it at higher rpm, that's where you should/might get the Nissan manual voltages.
;) Cheers :sleep:
hmm I had a CAS fail years ago on my r33, it was a real pain to track down, one of the most intermittent missfires I've ever seen.
Ended up paying around 400 for a second hand one - I almost had a heart attack at the nissan price....
Do you have a consult cable? You can get a reading off most of your sensors and make sure they are acting OK while you are driving
  • 1 month later...
guys and gals
didnt want to create a new thread to ask the question .. so found some talk of consult ports in here
can anyone send me / describe the consult port on a 2000 Stagea?
I have a consult cable that I used on my old pulsar and wondering if the pin outs etc are the same?
I have calumsult and nissan datascan etc. IT would be great if the consult cable can be used on the stagea too.
( ps I dont actually HAVE the car yet hence why I cant just try it out. Thanks guys.
Edited by ssshonky
guys and gals
my 99 s1 (late model) stagea has a 14pin consult connector
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
