hi guys
had my r34 for just over 6 months now and saved up a bit of coin for an upgrade. as i dont know much about turbo model names and part numbers i thought you guys may be able to help out on some recommendations. my goal is to hopefully be able to run a low 12 second pass on the 1/4 mile.
mods i currently have:
full 3'' exhaust
power fc
front mount
hybrid electronic boost control
heavy duty clutch(not sure of brand)
just purchased a pair of mt street radials
fuel system looks standard
turbo looks standard on outside
not sure if internal work has been done to engine
so far i have run a best of 13.2.
any surgestions guys?
thanks
Justin
https://www.sau.com.au/forums/topic/155997-turbo-surgestions-for-300rwkw-r34/
GT35r with .63 exhaust, should make it with 18psi, and be responsive, you will need fuel pump, 550cc injectors, probably valve springs and cams if you want to make it at lower boost. Just use an ebay high mount manifold, may need to upgrade exhaust(or run a sreamer pipe)
