Just be careful that you dont touch the glass when you install it. Most of the time the oil of your fingers causes the light to reflect back into the globe and creates extra heat to cause it to blow and
Those cheap crappy xenon globes are crappy.
If you're planning on getting the Phillips blue globes and expecting them to be blue - don't. I've got a set in my car and they put out a nice white light, and they have noticeably improved visibility, but if you want blue, then they ain't got it :) Mind you, I don't think that's a bad thing :D
  • 3 weeks later...
The reason why oil from your fingers on globes causes them to fail early is because they form a heat sink on the quartz.
In a halogen light bulb, the tungsten filament gets so hot that some of it evaporates into the halogen. Normally the evaporated metal condenses back onto the filament again because of the halogen, within a couple of milliseconds.
When you get oil on the quartz (glass would melt because these bulbs run much hotter than normal bulbs), it draws heat away from the rest of the bulb, and the metal starts to condense on this cooler spot in the bulb instead despite the halogen.
Eventually you will then the bulb will fail in the exact same way as your house light bulbs fail. There will be a weak spot in the filament because too much has condensed onto the quartz.
This is also why you don't have to worry about touching normal vacuum type bulbs. With these, either way the filament will evaporate and condense onto the glass, and it doesn't matter if it does this in one spot or evenly over the inside.
Because of the way normal filament bulbs fail, in theory it shouldn't matter if you get oil on a HID bulb because they don't work by evaporation.
For anyone looking at upgrading their bulbs, have a look at Daniel Stern's Lighting page. This site has convinced me to get some Philips Vision Plus bulbs as my next car purchase.
  • 1 year later...
Revhead: Sorry to correct you but i've got a set of Phillips 5000k temp and they put out a v light-BLUE light. !, so blue i wish they were WHITE, so i only use them as my High beam for looks only but they set me back $100.
Seriously its BLUE but it isn't as bright as the normal ugly yellow
Usually the temp determines the colour of the light, if you get 4200, 4300k temp then they are yellowish/white, if you get 5000k they are blue, if you get 7500k they get purple, i hope this helps.
My set has lasted for over a year, and my headlight is cracked and letting in water where it fogs up but it still ok.
its not worth the money and visability is poor, thats all i can say about BLUE light from NON-HID head lights =(
I rang up autobarn to check the prices of phillips light globes,
the Phillips Diamond Vision 5000k H1 i've got in my car cost $145 from AUTOBARN!
in my opinion its not worth the money because only for LOOKS but poor for visability for that price you may as well get HID's for $450-500.
Guys guys guys....listen to me
This is gonna be the best advice ur ever gonna get.
Go to Kmart or whatnot and buy the autotechnica super white/blue globes. They are cheap as, like 10 bukcs or something.
Now i know ur all gonna say but they cant be good, it's autotechnica, they are gay. Yes they may be, but i have gone through alot of money buying phillips ones, and they kept fckn blowing. So i got these ones and i tell u what, they are brighter and whiter than any of the phillips ones. And they are still goin strong, havent blown for ages.
Trust me, just get a set and see what ya think. Ur gonna sauve urself shitloads of money but also get better light
I bought a set of osram silverstar globes. They arnt super white or anything, but they definately work much better than the normal halogens. You can definately see a bit further and tell that its brighter. Best thing is, it only cost me 40 bucks. May not have much bling factor, but when driving along with no streetlamps, you really come to appreciate them.
another thing to check is the voltage of your electrics while the car is running, esp. under a bit of load, if your alternator has a dodgy regulator the voltage could be spiking too high and that can kill bulbs.
Get a mutli-meter accross the ciggy lighter socket and take it for a burn, with a passenger keeping an eye on the reading, if you have fancy data-logging one you can do it by yourself. Just don't come back saying you crashed your car while looking at the meter rather than the road! :D
just a follow up about the phillips range of globes
like revhead and crooser say, the vision plus/blue vision, emit a white light, even tho the lens is slightly blue. they are probly equiv to a hella cool blue, altho slightly clearer.
i have crystal vision in mine (4300k colour temp def not a yellow/white light as gtshortie mentions, they are very white) and they work a treat, i think a good compromise between white and blue, altho not strictly legal.
also as gtshortie mentions, many ppl are disappointed with the diamond visions @ 5000k temp, they are blue enough to limit brightness and will attract some unwanted police attention.
as an auto electrician i replace the odd globe and recommend phillips, even the standard phillips, altho if u buying crystal or diamonds try and do some haggling, there is a substantial difference between retail and trade prices.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
