Guys im about to buy a skyline today and i have a few quick questions, i dont have time for searching. Its a 91 mspec gts-t and i dont know about this but on side of the car where it has the gt badge its all silver i thought the t part of the badge is always red for turbo cars? the owner said the 89-91 models came with the silver badge meaning there turbo but after 92 they came with the red badge. Is this correct? are r32 gts-t's m spec's 91 still able to be driving on your p's in victoria? how much would the front brakes of a 32 mpsec front brakes cost? and is it possible for someone to check out this vin hcr32-070981. There was some sort of long number near the side of the engine bay that was similar to a vin? is there always a plate on the side of the engines bay's with a sort of vin code to it in these cars?
edit: can someone give me a link to what i should look out for when buying a 32?
Edited by Nth
https://www.sau.com.au/forums/topic/156417-please-help/
http://www.skylinesaustralia.com/forums/in...showtopic=35129
you'll be allowed to drive a r32 gtst on your p's if you get your p's before july.
(i'm not saying you won't get questioned, but technically yes, at the moment you are.)
not sure about your other questions though sorry.
https://www.sau.com.au/forums/topic/156417-please-help/#findComment-2906957
your asking these qusetions on THE DAY your buying the car... asking for a bit of trouble dont you think?
theres a thread in General Auto at the top of the home page called "Nissan Fast", that'll help you with some more info on the car. And i would imagine32 brakes are quite cheap... well the discs anyways
https://www.sau.com.au/forums/topic/156417-please-help/#findComment-2906983
People have taken time to respond to one of your other threads about this, and it seems you didn't bother to read the replies, if you had, you'd have found that the things you're asking (again) have already been answered.
Searching for information which has been covered time and time again is much quicker than starting a thread and waiting around for people to reply, so to say you don't have time to search is just silly. ;)
Please read this:
http://www.skylinesaustralia.com/forums/in...howtopic=113261
and this:
http://www.skylinesaustralia.com/forums/in...107253&st=0
and this:
http://www.skylinesaustralia.com/forums/in...howtopic=156220
and ask about the vin here:
http://www.skylinesaustralia.com/forums/in...howtopic=133729
There's no such thing as an M spec 32. :sleep:
Badges can be changed if you don't like the colour of them.
https://www.sau.com.au/forums/topic/156417-please-help/#findComment-2907091
just called the owner back with the 32 i got 3 numbers he said
the vin number is:
6t91mpv97y1net001
the special import vechile number is:
44356/1
body number:
hcr-070981
i think he has the body number mixed up with the vin number. Should'nt the vin number have 32 at the start of the vin code to say its a 32 model?
https://www.sau.com.au/forums/topic/156417-please-help/#findComment-2909024
the vin number is:
6t91mpv97y1net001
44356/1
body number:
hcr-070981
No the facft it has that Vin means it was imported some time ago under the old Low Volume Scheme
Your body number is the HCR32****** Number
https://www.sau.com.au/forums/topic/156417-please-help/#findComment-2909069
Guys i didn't end up gettin the skyline, was a bit suss wih it not being in the nissan fast program. Just got a question for when i find a skyline that im interested in buying, what is a good mechanic to take the car to get it all checked out for rust under the car compression tests all that.
Thanks
https://www.sau.com.au/forums/topic/156417-please-help/#findComment-2913918
there is a guy calles scott in mornington that specailises in imported cars, he is good i got him to do a rwc on my car to get the deffect taken off, but mornington might be to far for you. the name of his company is 'BLUE MOTORS" hope that helps if you still need it
https://www.sau.com.au/forums/topic/156417-please-help/#findComment-2914907
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
