doesnt work that way for me Sam :(
From memory (cos i did this packaged with a winery tour for SAUWA about 3 years ago) the more people you get together for it - the cheaper it becomes. The group booking information can be found on the swan valley oasis site - i tried to look it up but my work computer for some reason thinks its an "explicit site" must be all that talk about large balls.
  • Replies 138
also best way to do it - is get people to deposit the money in your back BEFORE the event with the no refunds if you dont turn up policy.
As nice as all you are a lot of SAUWA people say they'll be at an event then dont turn up - so this way you have a commitment out of people and also have the numbers all organised with yourself and the venue.
Guilty...Good plan ma'am
I need some input as to what people would like to do and when.
If we decide to play on a sunday we can only play a maximum of 9 holes (more than likely the front 9 which is far easier than the back 9). If we play on a saturday we can play the 18.
Cost is $12 per person per 9 holes with a discount offered (15%) to group bookings if paid in full in advance. I guess the easiest way to do that would be confirm your spot by paying me 2 weeks before the date so i can pay the booking, and receive the discount. I have not worked out how much it would be per person with the discount that we could receive.
I had thought to make sure as many people as possible can attend would be to plan early. I was thinking March 24 or 25th but that is obviously open to suggestion if thats not a good weekend (e.g. drifting event, or somehting that people would rather attend).
Have I missed any details that you guys want or need to know?
Regards
Brad
sounds good.
i'm up for either 9 or 18 holes, any day suits me except for march 4th (which is probably too close to plan anyway).
so that's my 9or18 holes and availability survey for you.
(i dont know where it is, but i'll look that up myself :P)
Location may also help people make the decision to come or not.
It is in the swan valley on West Swan Road. About 5 minutes from Roe highway. (Between roe highway and Gnangara Road)
Events wise - there is a MaxAuto Action on Sunday March 25th so if you are planning supa golf for the weekend of the 24th/25th... Donna and I would be in for the Saturday for 9 or 18 holes. If you can confirm this date I will drop you the dosh... if you can catch me Mr. Speed-cut! :P
Dude thats just not nice!!! Nissan gave me speed cut to give you guys a chance!!!
Saturday 24th it is. Tee off at 1ish? Decision decided!
Kids are welcome. Keep in mind, kids will slow play while looking for your ball that you lost! lol
Yup,
Saturday 24th at 2pm it is.
My suggestion is to do the front 9 holes as they are easier to play. It normally takes an hour and a halfish to play 9 holes so with a large group i dont think time will permit for 18.
Ill count up the numbers on monday 26th of Feb and make a booking, then take payments. Probably best into my bank account with a PM so i know its done, or other arrangments can be made. Will work these details out next week. Obviousy payments are non refundable.
Does that sound ok to all???
Regards
Brad
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
