Rules: You have to guess the movie quote. If you are correct you have to post another quote from a movie and let others guess it. A bit like a pass the parcel type scenario. I'll go first, I'll start with some easy ones
:D
Get your ass to mars $)&(*$)!# Get your ass to mars $)&(*$)!# Get your ass to mars $)&(*$)!#
https://www.sau.com.au/forums/topic/156790-whose-movie-is-it-anyway/
  • Replies 282
haha nope
its an older movie (comedy), james will know it for sure
Damn! ;)
pffft, James knows every movie and should be banned from competing. Infact, ban that Roy character as well, both tarred with the same movie buff brush and co-habiting 'n' all, it's a win waiting to happen. :D
"Tray, I don't want you hangin' out in the streets. I want you to finish school, 'cause without an education the only kind of work you're gonna get is sellin' drugs, pimpin' women, or workin' security for Eddie Murphy."
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
