  • Replies 153
puts some gooey gumballs on this arvo. soft as butter. hopefully they should hook up :O
haha hey grandad.. u running ur GTST..? im gonna run the R34 i so wanna run u lol.. ull win though as the GTT is running like a dog :wave: and its stockish lol
should be fun.. :)
Im ready to roll...
I have borrowed a EF28-300mmLIS lens from work and a EOS 5D... So the photos will be crisp...
Im leaving home in about 10 minutes... I should be a willowbank by about 3:40 or so... Ill be heading straight to the staging lanes with my mates, ready to run up against my mates SS ute... :D
I told him to take a good look at my front bumper last night, he asked why, I said cause all your gonna see tomorrow night is the rear end... ;)
Im ready to roll...
Im leaving home in about 10 minutes... I should be a willowbank by about 3:40 or so... Ill be heading straight to the staging lanes with my mates, ready to run up against my mates SS ute... ;)
leavin shortly in the blinged out bionic wheelchair. :D
Timing is everything... I zipped right up behind Col and his buddies coming onto the motorway heading for the drags :P
Got a little bit of video uploading now ... I wish people wouldn't stick their fat heads right infront of the camera. I couldn't get all the times from the left lane. :)
Anyway was a good arvo shame about your rear tyres Col that must of been frustrating.
Some Pics while I upload video.
What a downer way to end a fun evening, One of the heavy hitters in a rail failed to open the chute and, whilst it hasnt been confirmed it was rumored that it was a fatality. They closed the meeting early and we all left feeling a little humble.
but anyhooos, We had a blast until then. The blinged out bionic wheelchair ran a best of 14.1 and a best speed of 100.8 mph. Not a bad base to build a 12 second car from. Ben is hooked, couldnt get the grin off his face. His terminals indicate that when he learns to pedal the line properly hes gonna be quick. Col performed exactly to my prediction. TOOOO MUCH HORSEPOWER.LOL His terminals indicate that he should run low 12 or even 11s but until he gets it sorted hes just darn good entertainment. Sir skyline had similar issues, methinx there might be some cars wearing drag gumballs before the 17th rolls around.
Markimac if you dont get that gtr out there next time then you deserve every bit of shit fellow liners throw at you. That was pathetic. To make it worse you even went and parked beside me after that run. I just pretended i didnt know you,. hahahahahaha.
Great fun folks. be at the next one and join in.
ahaha..u love being next to my GTT.. :laugh: i knw.. its TCS and coilpack miss.. :) ok :) i told u when i first got ther lol. oh well.. if i dnt sell i may oneday be brace to head down again for an allmight 7k launch.. but i doubt it.. :P
