Hi guys, it's time to get back into something AWD so my R32 is up for grabs. I've owned it for about 5 months and in that time i've added Recaro seats, 4pt harness, custom tailshaft, alloy radiator, and had it tuned.
1993 R32 GTST Type M
114000k
Rego to June 07
210rwkw@16psi, 240rwkw@21psi
Engine:
RB20DET
Microtech LT12s ecu
Garrett GT28 0.86 440hp turbo
Custom modified exhaust manifold
Genuine Hybrid 600x300x75 FMIC
JJR 40mm alloy radiator
GTR injectors
Custom dump pipe
3" turboback exhaust
Malpassi FPR and gauge
Bosch 910 fuel pump
Custom cam gears
HKS air filter
Greddy Type S BOV
Driveline/Suspension:
RB25DET gearbox
Button clutch
Custom 700hp rated tailshaft
Tein HR coilovers
GTR rear swaybar
Hicas lock
ANZ 18x8.5" rims with 235/40/18 tyres all round
Extra 17x8 and 17x9 Impul rims
Interior:
Greddy Profec B boost controller
Greddy Turbo timer
Autometer boost gauge
Blitz steering wheel
Razo pedals
Recaro driver and passenger seats
RPM 4 point driver's harness
Pioneer DEH-P9650MP headunit (RRP~$1400)
JVC 520W 4ch amp
Sony 6" front splits
Pioneer 12" sub
Pioneer 6x9" rear speakers
Asking price is $16500.
Less $500 without Recaros (stock seats fitted).
Less $500 without stereo.
Will consider removing other parts to reduce price.
Located on the Gold Coast, please PM me or email neilesplin@hotmail.com with enquiries.
Pics
http://www.skylinesaustralia.com/forums/in...howtopic=156926
https://www.sau.com.au/forums/topic/156928-modified-r32-gtst-qld/
  • 3 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
