haha as in the people that sweep the track when people slide out, i would but after seeing the shit they got called last time im out lol
HOWEVER some of my mates are scabby losers and will do it haha
Far be it from me to be sensible, but without the marshalls & flaggies there would be no motorsport. At all. Ever.
It is a constant battle for event organisers to get sufficient people to volunteer. So maybe you could try encouraging your friends to show them some respect or even to volunteer themselves.
Giving up you day to assist other people is hardly the act of a scabby loser. Quite the opposite infact.
Peace, love & mung beans. :)
people yelling shit at ya from behind a fence are green with envy!!
I'd go sweeping but I have a 7yr old to look after.
If WA car events don't get enough help, they simply wont go ahead!
So fcuk the bogans and go sweep :)
I am so there!
Love being a post whore so I thought I would give being a drift whore a go :P
And why would there be Trevs at a drift event anyway? Wouldn't they all be at home saving up for the $85000 its gonna cost to get into the V8 supercars this year?
Seriously though, due to dedicating myself to having a family young, I have to live my motorsport fantasy's vicariously through others and volunteering at this sort of thing is definately the best way to do it. I have done the supertrucks, dutton and targa west rallies and now this - all for free, and sometimes you even get a free hat and/or shirt!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
