Why only coupes? I have sedan :)
What do I want from my LCD Screen? For me, apart from the fuel economy screen, it's pretty much all a gimmick, but I'm so glad I have it as without it there looks like there is something missing.
Firstly, I would preferably want it in English.
I don't really care about Navigation. By all accounts this is impossible anyway.
TV - I can't see why this wouldn't be achievable with little mods to the OEM.
Bits and pieces I have found from research -
the headunit is most probably made by Clarion - the US guys say theirs is but I can't confirm on the jap ones.
The software for ours is made by Xanavi.
http://www.xanavi.co.jp/products.html - go through and find the page that says Map Software - the BirdView one i believe is ours.
There are 2 Discs that make up the software - 1 Program disc/Firmware update disc(CD) and 1 Map Disc(Dual Layer DVD)
The US guys say they can change the languages from their menus.
I've had the US discs sent to me(they are made by a different company - http://www.zenrin.com)
The Update Disc complains about firmware being incorrect. The Map DVD does nothing. So don't bother with this route guys.
But I'm pretty sure you would be able to exchange the DVD-ROM Drive with the US one and have it work. Harnesses "should" all be the same. The ones for the stereo certainly are. But i'm not going to fork out this money without someone confirming this firstly. Oh and if it works your screen will say Infiniti instead of Nissan...
I am really interested in getting the Jap equivalent to these Discs. I didn't get them, if you have them, can I beg you for a copy.
The best thing to do is get someone who speaks Japanese call up this company and ask them about an update copy of the firmware - can they confirm if it changes languages? That alone would be worth a shell-in for us to buy a copy.
g35driver says what Chris says. You can buy a double-din facia and replace the HU but the aircon controls need to be swapped out for aftermarket at the same time. For me this is a bit expensive at the moment, and I am quite happy with the sound from the stock HU as is.
The TV module in my car is made by this mob:-
http://babelfish.altavista.com/babelfish/t....jp%2findex.htm
Mine says ATV-62 on the side. Is your's the same?
Again someone who speaks Japanese would be best to call them and ask them for a wiring diagram.
Can someone tell me the technical reason why the TV needs to be converted? I've never had it explained properly and I don't get it.
I have sent heaps of emails to heaps of Jap companies. Never with any replies. Could be the language barrier.
Also Maximas don't come with Navigation screens afaik? Only the Muranos and Patrols. But completely different systems.
Yes aftermarket connectors and harnesses can be hooked up for you to utilise the existing screen no problems. But I'm trying to exhaust OEM options(ie , do it cheap!)
putting that TV model into google gives this:
http://www.e-axios.com/other/tv.html
that lists all cars fitted with that unit.
still looking for the actaul nav unit. mainly for pinouts.
  • 4 weeks later...
No need for radical removal of factory audio to integrate TV, DVD, NAV or reverse camera for current V35 series.
Pics attached of a vehicle with Australian Mapping, and reverse camera. TV and DVD can also be intergrated.
PM me if interested.
We have converted a lot of V35's now and a kit is able to be made up and installed by a local installer if they know what they are doing, even got the new Cima working sweet as.
After trying every option best plan seems to be you fit a new unit putting it in the boot or under the front seat, leaving the OEM unit in the car due to other things it also controls.
Do not let some one "give it a go" as they can make a serious mess if they dont know what they are doing and the car is off the road a long time.
TV isnt hard to get working and the new Sat Nav system is controlled by a small remote with split screen and everything working.
Personally I have a OEM double DIN unit as mine is 6 Speed Manual and they dont come with Sat Nav.
Also you can order Double Din as per below from Japan Parts
Edited by Guest
Drift,
Can i get some specific details?
What "conversion kit" are you referring too? Is it available off the shelf or did you make it? Either way what's the price?
As for the new unit in the boot - Any recommendations on models?
I've looked into this myself, and the parts I've found that will get the Navi working on original screen, come up to over $1k, and I can't justify this when you can get Navi's for well under this now.
PM me if you like, any info is appreciated.
cheers
Bobby
Drift,
cheers
Bobby
for the navi unit you are correct. the CD based or is a touch under $2k and the flash version is $1700 or so (VDO)
as for the total swap - loosely $800-$1k before gear.
drift,
are you swapping the AC controls?
This link says it all for the English version.
http://www.nissan.co.jp/EN/navi.html
It also says this;
Q.Can I use the English DVD navigation system outside Japan?A.We are afraid not. The vehicle-installed GPS system can operate only within Japan and we do not have applicable maps for usage outside Japan.
There is a guy in Burswood, WA doing the VDO and TV conversions, retains the original DVD in the upper glove box to keep all the other controls sweet and mounts the VDO unit in the boot.
It also says this;
so I was correct. wht I would like to attempt is getting the display correct on the radio. mos of them use the same processor across the range (this is based on clarion.) and it is a hardwire setting that needs to change. the only thing that concerns me is the FM frontend and if it is tuned to the top end of the FM band. AM is fine.
actual link:
http://www.nissan.co.jp/EN/contact.html
before anyone else asks I want to attempt this on a V35. anything else can be removed and is not worth attempting :stupid:
same place I source from. good to see that someone else does too..
I get a lot of OEM items off Graham, on a new RX7 CAT he saved a customer of mine $2,000 on the one item.
Drift,
Brian who is the person at Burswood everyone in WA uses he can do conversion kits as a dealer in QLD needed to convert some cars.
For the double DIN conversion and no GPS you need to change the A/C controls and the JDM GPS unit has to stay in the car for various reasons if keeping the screen.
before anyone else asks I want to attempt this on a V35. anything else can be removed and is not worth attempting :ermm:
To my knowledge don't waste your time, Brian is a GPS Guru on software and everything else not just a person who installs stereos and it has been tried before.
I supply all the Schematics and so fourth for the JDM cars and he just did a 2005 V35 and it is way different again to the 2001/2004 2 door and 4 door.
The GPS units are put in the boot as a couple of people wanted it in the glove box but you need to move 2 computers and about 96 wires to extend.
No one to date in WA can even get close to how well Brian gets them running so email me at [email protected] and I will pass details on..
Nigel.
Edited by Guest
Nigel
You are right about Brian I was at his workshop this morning having a look at the 2005. He has it sussed there is no interference on the screen at all the Nav he out in works a treat.
He has worked out how to keep all the other stuff that the JDM unit does as well as install the new nav unit. He is falt out all the time but like you said in Perth no one comes near him as far as this sort of stuff goes.
Paul
Final nail in the coffin for the factory system. See email below from Nissan Japan.
Thank you for your email dated May31, 2007, concerning the DVD system.
With regard to your concern, we would like to provide you with the following information regarding the navigation system.
The English navigation system is available for only a dealer-installed Xanavi DX305 series DVD navigation system. The English navigation is not available for a factory-installed navigation.
In addition, we would like to inform you that the Xanavi DX305 series contains only navigation functions. It is not a multi purpose screen which includes audio, CD etc, control functions.@Therefore, your navigation cannot be converted to English.
Sincerely,
Katsumasa INOUE
Assistant Manager
Customer Affairs Group
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
