I did mine a few months ago.
I'm pretty sure the centre hole in the factory bush is flared out at the top.
It think the hole in the noltec bush is straight but the same size as the flare in the factory bush.
Have you looked at the studs to see if they are tapered at the base?
Don't worry about the clearance in the bush as it locks up rock solid as Cubes said.
Just an update on my bushes, i got the noltec ones refunded and the new ones arrived today, "nolathane evolution" part#49154 can be found at http://www.redranger.com.au/proc_selection.php
I am only replacing the 2 front bushes (silicon filled) for now, due to guys at work saying u need some play, and due to only the r/f being split which leaked all the silicon out so when i boost it sags down and heads left.
Removal of the bushes was fairly straight forward, support the subframe, found a socket big enough and the all mighty sledge hammer, wack wack, came out.
If using these bushes u need 2 reuse the orignal outer shell, so try not to damage it to much.
Once removed it was of to the gas cutter, just burnt out all the rubber and silicon until all was gone and until the centre feel out, on the outter part there is another 2 sleeves inside the outter one which you need, i simply grinded the end (bottom end of which u smacked out) so its flush then the sleeves simply punched out, leaving u with the outter shell, just grind and file to clean up the edges then i refited this to the subframe, just by applying a flat solid object accross the top and wack, outter shell is now back in subframe, now just simply insert the "nolathane evolution" bushes.
I recomend these bushes if you are replacing them for a gts-t, my opinion, but the crush tube is slightly tighter which fits more solid onto the mount, and the fact u dont have to hack 12mm of the bush and crush tube like the noltec ones.
Am still yet to refit subframe to my car, but will post and update when i have of how it feels etc, I hope this helps
Honestly mate those bushes look like a bad joke compared to the noltec ones but since you have them fit the rear ones while the cradle is out.
It's nonsense to suggest you need movement.
Any increase in NVH is minimal but would be present anyway because you have replaced the front bushes.
Just received a reply from Noltec.
Thanks for your inquiry,
We have been supplying part # N92447 for R32 models fro some time now without any issues.
Yes we do offer an almost identical bush but 12mm shorter.
Part # N92446 Price $190
Regards,
Andrew Nolan
Marketing Manager
Noltec Suspension
So there we have it.
  • 3 weeks later...
Fixing the rear problem (ie the worn subframe bushes) makes a huge difference to the stability of the rear end.
In addition to that pineapples can help change the angle of the diff and subframe a little for more traction - but most people use them as a dirty fix to cover up rooted bushes
unless you want to change the inclination of the subframe, you don't need the pineapples once the subframe bushes are done.
mine have been done in the GTR and it adds a bit of NVH but much stiffer and controlled :)
do it ;)
  • 3 weeks later...
just a question for the guys who have installed these noltec bushes. i've just installed some in my subframe and was wondering what if any torque settings you guys used to do them up? or did you just do them up as tight as you could?
  • 5 months later...
110nm would be the torqe needed
cheers kyle
  • 1 year later...
I am about to do this job myself.
After doing a bit of research I am going to use the Nolathane bushes. Part # 49154 and if you want to do diff mount #49162.
The good thing about these is that you don't need to remove the outer sleeve from the cradle at all, just cut/burn out the old rubber. grease up the new bush and push in.
No ten bizillion ton press needed. :ermm:
http://nolathane.com.au/install_guides/50-9154.pdf
Fitting guide above.
Will post results after.
Edited by guru_ray
  • 3 weeks later...
Hey nice write up been looking for one like this.
Quick question for the pro's, I wanna use some alloy pineapples does that mean i just slide them over my stock cradle bushes? Or do i have to remove the whole stock bush?
Cheers Davo.
  • 5 months later...
I just got these from Whiteline.
Part Number: #W92446
For R32-Gts-t
Installing tonight or tommorow.
I bought a non hicas rear end, but I was supplied arms, but it seems they are the wrong ones I need traction rods? Can anyone verify the length of the stock traction rods for me?
Cheers,
Michael.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
