Annual Sau Dyno Day Pictures/video And Discussion
  • Replies 140
There was no doubt in the figures previously recieved just interested in the variation between alot of cars with similar or more extreme mods than above mentioned, although closed on arguing this, will do my own r+d for improvement :P altho well done on that figure anyway Cheers A
Will be doing some r+d on this topic at my time will post results when i ascertain where i went wrong as my torque reading should be alot higher aswell especially with the mods and turbo choice i have gone? will keep people posted on this result and for those concerned YES i will use richards dyno again as this is the only best was to compare results and limit the possibilities of errors that could be very well encounted. Col is right on one area the comparison of results is very important hence why such use of the same dyno is important as it gives you far better chance in finding what you have done right what a certain problem may be. and if you change something does it improve or not improve results.
Lastly the original tune done by richard on the same dyno was read at 208 rwks with the same tyres but after noticed the tyres were slightly flat well 14psi difference so instead of 38 both sides one was 24 one was 36 psi checked the day after results. And aparently on the same boost. Interesting? So once my injectors are in my new boost controller is in will take back for a freshup tune and get results hopefully more improvement.
From here will locate the boost guage in too different spots one before inlet of cooler run that and then do a recheck on result verses outlet of intercooler, This will eliminate the source that the cooler is or maybe the bottleneck in my mods. This will clear alot of things up. Tyre choice could be an issue so if someone wants to let me there tyres/rims for this session would be also interesting to see if this improves/or leaves result as the same. Not many possible bottlenecks i can see after this. cam choice Maybe? As i am running standard cams, yet tho this may not be an issue. TB or inlet plenum it could be but have seen these items past 300rwkws (Col) and many more on this one im not sure if that is such a restriction issue.
But once when i have further results i will be surely able to clear a few issues up here.
For those interested my torque figure was 1364 N.M at 132 kmph. For those wanting of my mods those members may clear that up on page 4 in mod thread of members section.
Thankyou
Cheers
Adam
So was my car the only car to piss out oil onto the floor :P Something that i dont understand tho, I had a max torque of 1259 Nm on my printout. But from factory is 353 N·m. Whats going on there ?
1259 Nm is at the wheels, so your diff ratio will multiply your real fly wheel NM's...
In short find out your rear diff ratio and take thr 1259nm and devide it by the diff ratio to get the fly wheel NM... Simple... :)
Hey Adam, have not be ignoring you just be super busy with photos/video and trying to answer a million questions via PM.
Ill give you all the info you need to know in the next few days, but yes in short I have stock cams and a stock inlet manifold. But a few key modifications are needed to push the extra ponnies... I will talk to you soon...
Edit... Oh forgot, its a Garret brand GT30 0.7 front cover and 0.82 rear with external wastegate. The trim is standard GT30/40 Garrett issue.
No problem col, i realise the busyness you are in at the moment, must say is this alway like this for ya after a dyno event :P lol
No fortunatlly... :)
But ideas and feedback via PM is always welcome, cant improve unless you know where to improve...
glad you can see and understand out point of view col. again hats off to the execs.
power figure wise, it doesn't matter if it's reading high or low. as long as it is consistent (which it wasn't)
i suppose people prefer dyno dynamics to other dynos, because not only does it have a higher power reading. BUT it is considered a standard i.e. autosalon, etc.
edit: what nathan said.
top stuff
What a great day...
Thanks to everyone....
i had so much fun! hey col it was 181 sif rob me of the extra 1 kw :D:wacko:
met some new people had fun with the old sif post photo of my looking so seedy....,,
once again thanks to everyone who organised and ran it.... i love Marc's sausage.. it tastes so good :huh:
Who owned that white 33 with the bomex/veilside looking kit with the nose off? That was the most incredible engine sound i've ever heard, and i'm not even into cars that much.
Seriously wow :wacko:
That would be me by the sounds of it. I love the sound of it too I cant get enough of it
I only had the bar off because there no way I would of got over that hump to get on to the dyno.
Spewing about the power figure thou. Theres something wrong somewhere. I got 330rwhp ages ago with a lot of problems and clutch was one of them. This time 90% of the problems have been fix and cams put in but I got a lower power figure but the car feels a lot faster on sure of that. Ill say the std clutch would not of helped it in anyway thats for sure,
Ill the car to gavan woods to find the problems, install the new clutch, and tune it and hopefully then ill be pushing 300rwkw's
EDIT: And it only hit 0.55 of a bar on them runs. Thats the other thing I need fixed
Oh Please explain on this lol. sounds like fun. Cheers A
One thing I learned from the day...
Remember to ensure that your bonnet is properly closed before hitting the gateway at 100km/h driving home afterwards :|
yeah no shit, 230?kw as opposed to me expecting 330-350 ish
thats quite a variance
i had fun regardless, and the SAU crowd *always* makes the sunburn worth it
Obviously they opened the bonnet to check before the dyno, and when I drove it out again, I never noticed they'd only just laid it back down and not shut it properly (probably shouldn't have been staring at all the far sexier skylines and paying attention ahead instead).
So I hit the ramp onto the gateway, hit 100 and just see my bonnet start wobbling like crazy (it seems that 100 is the magic number for getting it to do that, doing 60-70 all the way up sandgate road and it just sat there and didn't move).
I was just like... oh shit... the first exit wasn't for at least a couple of k's down the road, those where some "fun" k's.
I believe shootout mode was created to remove differences between dynos and conditions at different workshops on different days. Whether shootout mode reads high or low is irrelevant as it should always be consistent.
Agreed
You'll be there in no time Jarrad...
Yeah at half a bar with a slipping clutch i reckon you did well to get 230rwkw...
Cant wait to see her with a new clutch and some more boost...
You should catch up and ill have to put some cams in to reclaim bragging rights... :wacko:
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
