got my car serviced yesterday and while my car was on the hoist we found out that my right cv boot is blown and there was oil leaking everywhere... can i still run on the track with this condition?? (i couldn't find anyone who was willing to recondition my cv boot @3pm on saturday of long weekend... :) )
  • Replies 211
I will be there with Unique Zed with new R32 GTR diff 4.3 ratio which should be interesting as first time out with lots of changes. I think may run out of legs down the straight going from 3.7 diff ratio to 4.375. Will be good for Wakefield and Oran though. Weather looks like will be perfect and public holiday should be a big one.
Does the BBQ accept Green prawns and maybe some egg plant or only snags for the V and Coke drinkers?
Join the club with my speed limiter still in place :)
is there anyone just turning up hoping that someone will drop out so they can run on the track?
i *might* drop out thanks to the cracked right cv boot...
keyword : *might* ... i really wanna run this time coz 5 of my friends r running too... but if it doesn't look good, i might just have to drop out... and fix the damn thing for next track day on the 24th july...
This cold weather is giving me some trouble, noticed pinging earlier, been out and stuffed in some octane boost, hope that will sort it, first time I've tried it.
My track tyres were showing 18 psi after 5 kms from cold. So put them up to 36 psi, but might lower them again on the track. What kind of psi are most people running with 225/50/17s ?
About to take out the stero, shed a few kgs. Easier than going on a diet.
See you there ! can't wait !
Julian GTS-t
Popped the bonnet to do an oil change today and found a half dozen or so well done snails on my rocker covers.
Might have to drive a little faster so these bastards can't catch me!
Pete - I'm up for helis as usual, you bringing the gtr or the PIMPMOBILE?
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
