Hi Guys.
so i have done some searching and haven't come up with much, but then again, my search skills are crap.
I need to replace my manifold gasket, and while the car was off the road, i figured i might get one of these, but i do not know if they are any good.
I only have a stock turbo at the moment, hoping to upgrade later on down the track.
I know stainless steel manifold are usually not too good, as they tend to crack, so i was wondering if anyone has had any experiance with these manifold, also i know it would not give me necessarly more power, but would it help increase responce at all?
Any of is great thanks.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...mMakeTrack=true
I wouldn't paint it. It probably won't hold, and it'll just burn and flake off.
Sure, sandblast it, but it'll just rust again in no time.,
Most likely your manifold will have warped and probably won't seal on, so you might have to get the mating surface machined.
Yeah i have a spear manifold i am getting ready, so i will prep it all prior to teh other one comming off. I have some 1500degC paint, it takes 6 coles and needs to be baked between each coat. Has some alluminum stuff in it or something.
i made the mistake of buying one, didnt even fit on (unless i used some sort of a spacer, but whos gona use a spacer?) like every1 else has said, dont buy it, but a brand named manifold
p.s i was lucky i got my money refunded
Have you considered comp coatings? I got mine done(with a whole lot of other stuff, wastegate, ex housing inlet manifold) and it cost $350
Sorry my slow brain........comp coating??? Please explain?? Thanks Adriano
Competition coatings i think is a company that does ceramic coatings for manifolds and exhausts and whatnot. Like HPC and whatever other companies around that do ceramic coatings. You'd only ever do the black (highest temp) coating as the normal silvery one cant handle the heat in a turbocharged system. We had our dump pipe on the race car done in the silver and it just flaked off after a few race meets.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
