Hi there.
I have a sauce that allows me to get baseball/bomber
jackets for min $50.00.
If any members like the idea we can do a bulk buy
min of 25.
The size range is good from 14 to 30.
button up
pockets on each side
black
The photo has been added.
A big thanks goes to B-man
The company doesnt do logos,
but what two colours do we want to have.
I will be getting one for myself and my partner.
The names I have so far are:
Xzotik1 +1
Tonygtst
sw20-gt
mrrb20
carlo
doctor
knat
majanal
sumo
ender
lozza150
jimx
entysu
endorean
amy
I can put the order in any time now
so please let me know who wants one
pm me, email me or post here.
cam...:bahaha:
https://www.sau.com.au/forums/topic/15824-jackets-for-sau-min-50/
  • Replies 43
I'm in. What size is my jacket though? I only know my pants size! My T-shirts and casual shirts vary between M and XL depending on brand (sometimes M and L on the same brand but different shirt types are the same size!) and I can't remember the sizes at all off the couple of jackets and pullovers I own. My business shirts I think are 42 but that's a neck size.
Do jacket sizes vary much between sizes as do shirts?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
