Hey all, was driving along and my car started running rough so i pulled over, it sounded like i was running a huge set of cams. I turned it off and waited a while and then started it again it ran rough and thenit smoothed out so i drove it slowly home and parked it
I then started it again and it was running like shit and then it just died on, and now it wont start.
I change the fuel filter but that was just wishful thinking.
What do you think it could be.
It runs a Ltx 12 microtech so it has no AFM.
Thanks guys.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/
Does the engine turn over? Electrical fault? Charge in the battery? If electrical fault is messing with the ignition, the engine may be dropping a cylinder or two causing it to run rough? Dunno, just guessing from the info you've given.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2942156
Yeah i know mate it could be anything its a hard one, just wondering if this has happened to someone before.
No the engine wont turn over, but i have ignition and fuel.
And another thing it had a wierd burning smell coming from the engine so maybe it is electrical.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2942241
are you running a plug and play adaptor with the microtech? ive had this problem once, car did same shit, id say the cylinder are full of fuel and it wont start, take the plugs out and or make the injectors not pulse, then crank crank crank it for ages till it clears, best bet is to take plugs out, then goto your ecu and make sure all the pins are in place and theyre touching all the time.. i.e wiggle the harness and make sure it doesnt cut out....
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2942555
Thanks for all the advice so far i will try it all tomorrow.
I was just driving the car normal around 3-4000rpm going up a hill.
^^ i run a MSD ignition with a Ford coil pack.
Edited by subzeroR33
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2942689
Its all fixed, checked the spark plugs they were covered in a sticky oily black sludge.
I didnt think to check them as they were irridiums put in about 12,000 km, they are spose to last 100 000km.
Anyway i will be saving my money in future and just buying the normal copper plugs for around $20 not $120.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2959444
you're not worried as to why they were covered in oily sludge?
Well the microtech would have something to do with it, the injectors just flood the thing on start up so i spose over time they just foul up and probly to much upper cylinder lubricant.
Will keep a close eye on the plugs this time if they foul up to quick then i will need to fix this problem.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2965356
It was playing up again today, does this sound like an issue with the coils.
It misses and then comes good, short time later it missesd then comes good. It is really shiting me now.
check your crank angle sensor plug might be coming loose or not plugged in properly or there is a short in the wiring, i had similar problem on my old mans 32 gtr where plug seemed to be plugged in but wasnt fully clipped in, it caused rough running and a really bad miss. I checked the plug and clipped it in properly and problem was solved. Also check if you have a good connection at the battery/ground to ecu is very important. And yes it could also could be a coil starting to break down especially if you are using a ford one :ninja:
Edited by drf76
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2968679
check your crank angle sensor plug might be coming loose or not plugged in properly or there is a short in the wiring, i had similar problem on my old mans 32 gtr where plug seemed to be plugged in but wasnt fully clipped in, it caused rough running and a really bad miss. I checked the plug and clipped it in properly and problem was solved. Also check if you have a good connection at the battery/ground to ecu is very important. And yes it could also could be a coil starting to break down especially if you are using a ford one :)
I will check it out. Im also getting a knocking sound from the injectors. May be a fuel thing to.
Yeah i know Ford coils :ninja:
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2968713
haha ford, i work for them but anyway yer could be injectors but when you said your spark plugs are pretty bad you tend to think its spark related, but you gotta somewhere, hope you find out what it is soon with out too much hassle :)
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2968723
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
