Hey all, was driving along and my car started running rough so i pulled over, it sounded like i was running a huge set of cams. I turned it off and waited a while and then started it again it ran rough and thenit smoothed out so i drove it slowly home and parked it
I then started it again and it was running like shit and then it just died on, and now it wont start.
I change the fuel filter but that was just wishful thinking.
What do you think it could be.
It runs a Ltx 12 microtech so it has no AFM.
Thanks guys.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/
Does the engine turn over? Electrical fault? Charge in the battery? If electrical fault is messing with the ignition, the engine may be dropping a cylinder or two causing it to run rough? Dunno, just guessing from the info you've given.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2942156
Yeah i know mate it could be anything its a hard one, just wondering if this has happened to someone before.
No the engine wont turn over, but i have ignition and fuel.
And another thing it had a wierd burning smell coming from the engine so maybe it is electrical.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2942241
are you running a plug and play adaptor with the microtech? ive had this problem once, car did same shit, id say the cylinder are full of fuel and it wont start, take the plugs out and or make the injectors not pulse, then crank crank crank it for ages till it clears, best bet is to take plugs out, then goto your ecu and make sure all the pins are in place and theyre touching all the time.. i.e wiggle the harness and make sure it doesnt cut out....
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2942555
Thanks for all the advice so far i will try it all tomorrow.
I was just driving the car normal around 3-4000rpm going up a hill.
^^ i run a MSD ignition with a Ford coil pack.
Edited by subzeroR33
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2942689
Its all fixed, checked the spark plugs they were covered in a sticky oily black sludge.
I didnt think to check them as they were irridiums put in about 12,000 km, they are spose to last 100 000km.
Anyway i will be saving my money in future and just buying the normal copper plugs for around $20 not $120.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2959444
you're not worried as to why they were covered in oily sludge?
Well the microtech would have something to do with it, the injectors just flood the thing on start up so i spose over time they just foul up and probly to much upper cylinder lubricant.
Will keep a close eye on the plugs this time if they foul up to quick then i will need to fix this problem.
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2965356
It was playing up again today, does this sound like an issue with the coils.
It misses and then comes good, short time later it missesd then comes good. It is really shiting me now.
check your crank angle sensor plug might be coming loose or not plugged in properly or there is a short in the wiring, i had similar problem on my old mans 32 gtr where plug seemed to be plugged in but wasnt fully clipped in, it caused rough running and a really bad miss. I checked the plug and clipped it in properly and problem was solved. Also check if you have a good connection at the battery/ground to ecu is very important. And yes it could also could be a coil starting to break down especially if you are using a ford one :ninja:
Edited by drf76
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2968679
check your crank angle sensor plug might be coming loose or not plugged in properly or there is a short in the wiring, i had similar problem on my old mans 32 gtr where plug seemed to be plugged in but wasnt fully clipped in, it caused rough running and a really bad miss. I checked the plug and clipped it in properly and problem was solved. Also check if you have a good connection at the battery/ground to ecu is very important. And yes it could also could be a coil starting to break down especially if you are using a ford one :)
I will check it out. Im also getting a knocking sound from the injectors. May be a fuel thing to.
Yeah i know Ford coils :ninja:
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2968713
haha ford, i work for them but anyway yer could be injectors but when you said your spark plugs are pretty bad you tend to think its spark related, but you gotta somewhere, hope you find out what it is soon with out too much hassle :)
https://www.sau.com.au/forums/topic/158467-it-just-stopped/#findComment-2968723
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
