On the weekend i was carrying some paint in the back of my car so i put a towl in the cargo area to protect the boot carpet. After unloading the paint i closed the back door and the towel must have been in the lock area because now i cannot open the back door. I am a bit stuck on how to get the door back open. Any suggestions?
  • Like 1
https://www.sau.com.au/forums/topic/158716-my-boot-wont-open-help/
no idea mate...is it worth trying locking and unlocking it a few times - it may make it worse, or it may make it better, i do not know... Don't kill me if it breaks anything though...
Otherwise all i an suggest is undoing the inside panels from inside the boot to get at the locking mechanism.. all the panels should come off...
Or just call a LOCKSMITH???
Hmmm I had the same thing happen once with my '92 Falcon wagon. So I know how you feel.
From memory I worked at it from inside, with a kraft knife to shred the cloth, and a screwdriver to pressure the latch. It was a real bitch. The cloth tends to keep the latch closed and the hatch holds the cloth tight. It may help if you have someone on the outside, to push the tailgate in slightly (so that the latch isn't under the same pressure. I know that mine went very suddenly and then just released (opened). Other than that there isn't much that you can do (or a locksmith come to that). The bolts holding the lock on are underneath the lock. So they wont come out with the door in the closed position. Try having someone hold the handle in the open position while you sit down and put pressure on the bottom of the door with your legs. If you can get at the latch you may be ableto trip it with the screwdriver, or you may have to make a "tool" to enable you to do this.
Bear in mind tht it is only jammed. It should give in the end, after a bucket of sweat!
Best of luck.
Tell you what, I bet it NEVER happens again!! :D
I just realised that you are in Perth, (I think). So if you want to come around and see how the lock works and looks while it is in the open position, PM me.
Edited by Appealing
It might also be the auto closing mechanisim that has jammed, this happned to me once when one of the straps of my kids school bags got caught, I just kept pulling it out, like trying to open the rear door from the outside very harshly and eventually it opened.
But I did notice that once the auto closing mechanisim closed it made a wierd sound, and I looked down and saw the strap right where the locking mechanisim is.........
Finally got it open. I must admit i did not try to hard as i havent needed to use the boot too much recently.
I got it opened by getting my wife to push the door from the inside while pulling back on the towel. I was on the outside lifting hard on the handle.
The self closing mechanism doesnt help because normally you would notice this kind of thing when closing the door. As you dont have to slam the door shut it is not until it is too late you notice something is jammed in there.
For future referances all you need to do is take the plastic trim around the window off, then the locking caps for the carpeted trim and access latch from there. Push down on the part with the yellow bush which has the push rod attached.
  • 3 years later...
sorry to bump an old thread, but something is caught in my C34 boot latch, and it won't open
as far as i can tell, you can't take any boot trim off as you can't access any of the screws/pop rivet things?
will try just forcing it open with my feet from the inside (while someone is outside holding the latch open, but putting pressure on the boot toward the car???)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
