Nathan weisel has one in his 26 powered 32 gtst, seems to be nice and responsive. i will be running either K5-660R or twin T517Z's..... cant make up my mind.... both sitting here waiting on my decision.
Edited by URAS
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948264
The power output of a 3582r is just over 600hp, alot of people say they are 650hp but its not true. Garrett themselves rate the turbo as capable of 400rwkws on a 3litre engine, typically 25 and 26 30dets. Thats about 530whp or roughly 600bhp give or take 10-15hp.
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948335
Ive done one with a .63 ex housing to make it responsive, as it is a street car. Heaps of workshops said it wouldnt work. Anyhow standard motor, pfc, 550cc inj. 309rwkw 16 psi. 330ish at 18psi, havn't adjusted cam timing yet, so more to come. Nice and responsive, comes on at 3500ish, been running for over a year. I dont know about 400rwkw, unless the motor has cams, headwork etc, but 360 i recon no worries. Wont work hahaha
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948403
This turbo would be pushing sh*t uphill to do a +400RWKW, I done one a few years back with a 1.02 rear housing with a modified front, motor was built from sump to cam covers, and it produced, wait for it.
A pissy 470RWHP on 98 fuel
But to pay due when it is dserve, the turbo was on song for the most part of the rev band and nice flat torqur curve.
Disclaimer: I donot claim to be the great car mods, or have absolute knowledge of everything mechanical.The results are from personal experiences and may not be reduplicate at a later date or by 3rd party
HAHA
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948478
Todd wilkes Gicottoll omade 1200 rwhp with two of these on 18psi, but he had a full house 5.8 spinning them with a modified 1.06 ex housing.(The engine flowed soo well that the car was going over 15psi horsepower heroes limit with both 50mm exwastegates valves removed, thats why we machined out the ex housings)
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948558
Ye, you'll be pushing the limits for 400rwkw i reckon using PULP.
Thats firmly in the t04z territory of the 400-440rwkw marker.
A GT35 would sit around the 340-380 mark comfortably with good response.
Depends on the motor and all things associated of course as to which end the number will sit etc etc
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948699
one rb25 i did made 456 rwhp -335rwkw @25psi on 98 octane pulp fuel
it was a stock rb25 with tomei poncams and splitfire coilpacks.
that was with 1.06 rear, it hit full boost at 4500rpm and was very street unfriendly.
the .82 rear would be sweet
Edited by extreme turbo manifolds
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948765
There's a few here in SA that have basically just been bolted on.
It appears ~20psi makes a shade over 300rwkw.
I'd assume the difference between 20psi making 340-380rwkw and 20psi making a shade over 300rwkw is nice exhaust manifolds, plenums and a decent set of cams.
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948787
well im hoping for 400 in ours with the gt3582r...had 370 before with the gt30..so another 30 kws shouldnt be too far outta reach with this new motor. I reckon its possible. I guess time will tell though. However it will be definetely right on the limit, thats for sure.
Edited by r33_racer
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948793
370rwkw from a GT30... on PULP?
If so what boost levels/setup were you running to achive that? Must have been a fair lean on it either way.
Everyone else here with a GT30 gets around the 300rwkw with 18-20psi.
To add another 70rwkw is to put it... a fark load more :O
I was 24psi on 104 octane and made 369rwkw. The fuel made the difference there however.
Would not have come close on PULP. 330rwkw max with some ~23-25psi based on what we saw which slots perfectly into other peoples results such as bigcarl and a few others of late
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948847
r31nismoid if you followed the rb30 thread a little more you may have noticed it around there abit. Ive spoken about it several times and so have others.
In our racecar we run a 25/30det with a fair bit done to it. Head has a slight port n polish same as everyone else normally, tomei 256 poncams, 6boost mani, greddy mani, 850cc sards, powerfc, the gt30 .82 with a 3" zorst, no muffles cat, just straight through, 48mm progate, ati dampener, 8.3:1 comp, acl mls hg, water/meth injection, 8krpm.
On shell 100 pulp on 19psi (i think 1.3bar) we made 370rwkws and 385rwkws on 22psi 1.5bar..knock was too high though so we kept it at the 370. The water/meth injection added an extra 50kws, a heap more timing was added for the extra power. Before the water/meth we were only at 320rwkws on 17 or 18psi cant recall now.
Edited by r33_racer
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2948974
Cheers :O
I thought it wouldnt have just been PULP alone. Good results thats for sure.
It would help others if you stated that each time you quote the power figure too (would have stopped me asking hehe)
Like i do with mine if it was PULP/104/whatever etc
I dont remember all threads, all posts mate. I read a lot of stuff each week
RB30 thread, im only upto page 60 or so at the moment... another 200 to go (im cleaning it up)
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2949004
my apologies mate...its abit annoying having to state everything everytime....so i just try to cut to the chase. But with something like that in this circumstance i prob should state those things which might keep people wondering as to how that power was achieved.
https://www.sau.com.au/forums/topic/158731-gt35r-on-rb26/#findComment-2949040
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
