In relation ot previous post
http://www.skylinesaustralia.com/forums/in...57857&st=20
Here it goes again.
So basically, lately, it seems like the car in the morning simply does noo want to start, it coughs and so forht and carries on for 5 seconds, then fine, smooth as silk idle nothing. Almost like it only runs on 4 cylinders first and then all 6 come into line.
It only does this if it has been standing overnight, but lately also during the day. Once hot or anything no issues.
So so far i have done the following.
-New plugs, All good.
-Checked compression, still all 150psi eaven.
-Checked for vacume leaks, but vacume appears to be as per before, still to do more searching.
-AAC valve cleaned, and rechecked, and appears to work correctly.
-Redline fuel injector cleaner, special stuff
-Checked for head gasket, and all good.
-Put a new ECU temp sensor in, no good
-rechecked timming, and still as per before.
-cleaned air filter
-Fuel pressure and floww correct
-Spark plugs all look even and nicely coloured.
-Can was tuned 4 weeks ago, this started 2 weeks after.
Still to check AFM and fuel filter, but filter was redone 5k ago.
What i did was to reset the computer, drained all the fuel out of injectors, oped all the air bleed vents, and then restarted it the next morrning, and it still did it.
If i turn off the ecu temp sensor, it is fine, if i disconnec the AFM it is fine.
I have not checked Consults yet.
What i need to know is, how do i check the Cold start Valve and the FAST IDLE VALVE? Apparantly the skyline has these.
I am at a losssss???????
HELP.
My R32 GTR does the same, on mine I don't think its really that bad.
I put it down to old(stock) coil packs on mine, that and maybe the cold weight of the oil being to thick?
Otherwise give a respectable tuning shop a call, won't hurt to ask.
Have a a similar problem on mine, the cold start valve was adjusted to it would rev a little higher when started, which seems to help a bit. however i'd check out your afm and clean it thoroughly with "start ya bastard" or somethin similar, could just be dirty? but you have gone through most of the main things, so you must be close!
I noticed with my PFC if the load points 4-8 @ 400rpm were leaned out it would cause this stumble.
Richening them up rectified the problem OR another way around it was to dial in more injector cranking time (ms) at the relevant 'stumble' engine temperature which for mine is ~10-20degree's.
Have you tried turning off the SAFC to see if it still does it?
Mine always had a hard stumble start with the stock ecu.
PowerFC allowed me to tune it out so to speak.
I think there's definitely a problem underneath that is shared by both the R32 and R33's.
Just what is it? In my instance I have worked around it but really its just a patch up.
I'll be a little more clear. :P
Stock ecu.. Hard start stumble. Occasionally it would start nicely.
PowerFC Untuned.. A little stumble but no where near as bad as the stock ecu.
PowerFC tuned.. Hard start stumble on par witht he stock ecu. (noticed load points 4-5 @400rpm were leaned out, richening up these load points reduces the stumble)
PowerFC tuned but with my fiddling.. Cranking time increased to around 35ms.. Perfect start no stumble just vrooom. :P
From what I've seen it appears it doesn't get enough fuel. Pushing in more via the cold start cranking time sorts the stumble.
nope not yet, the thing is it never use to do it, it just progresivly got worse. like something is not working correctly, but not sure what.
same here,
When my car came fresh off the boat, it started on colds no worries and was perfect.
Then after the first couple of weeks it started to struggle and it pretty much got worse and now happens every morning.
I wonder if the r32's in Japan have the same problem?
I also heard that if you leave your car untouched for 2-3 days it will start much easier than when you start it the next morning. Another rumor i've come across :(
might wanna check the battery voltage on start up and idle charge and reving around 3500rpm could be not enough charge getting to battery
my 32 used to occasionally have a start problem i ran a 125amp cable to the battery(in the boot) and it has been good every since
voltage should be around 10-11.5 on start, 13.5-14.8 on idle and around a lilbit more on reving
it has the stock fuel pressure reg and and aftermarket one. However the reg has beenon there for 6 months with no warries, it has always worked fine. I am not sure about the priming, but tyhe fuel priming sounds thesame as it has always done.
HOWEVER, this morning the problem has seamed to iron itself out, no issues what so ever, so who knows, will see how the car goes.
ONE more thing, i notice that my car vacume is about 1-2 mm HG lower then before. I have a SPARCO guage, and did a test, and the pressure line, when you put pressure in it, doesn't hold pressure. SO basically if i pressure rise it, it bleeds off to zero slowely. So i redid the lines, and still does it. I can't hear a hiss, but was wondering if they are suppose to do that?
I don't think i have a leak, but need to check.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
