  • Replies 490
Posted Images
My pleasure... I'm starting the next one immediately as there's a few people with urgent brake needs... so if anyone is interested please pm me.
anybody know if it's possible/easy/cheap to get a bracket to allow fitment of a GTR sized rotor (324mm) in place of a GTST rotor (296mm).
its for an R33 if that matters.
d'ya reckon a bracket from a GTR would be a simple bolt on? cos i'm thinking it would be a good upgrade to just buy the GTR rotors from here?
edit:
don't worry, i'm an idiot, obviously the calliper is not going to provide the correct contact surface for a bigger rotor :blink:
anyhoo, can you put me down just for a set of regular slotted's for the front of a R33 (bills suck!)
Edited by made_guy
Hi mate,
This is an illustration of what Grooved rotors look like.
The dimples are not drilled through as to maintain the rotor strength, as too much cross-drilled section in a rotor may reduce it's strength and developing cracks starting from around the drill holes, the dimples also acts as an extra cooling in addition to the grooves - just like a cross drilled rotor.
Hope that helps. I have never put one on my car, but with the Gold Passivated material on the grooved rotors, I would believe that will reduce oxidation that mostly cause those ugly surface rust-look on standard OEM rotors.
Could you please PM costing for front and rear slotted (only slotted) discs for S1 R33 GTST?
If possible please also include costs for all four corners of Greenstuff pads?
Thanks a bunch!
Chasing prices on rotors for front & rear of my S1 R33 GTS-T, frieght is to 4214
FRONTS = Slotted/Grooved & Dimpled
REARS = Slotted/Grooved
Cheers bloke. :)
Also, quick curiosity question.. Are the rotors a simple slip off & slip on job, with just the wheel bearings to freshen up & nip in ?? I had someone tell me that they needed a press to get the bearings on & off - sounds a bit much to me just to fit a pair of rotors. I've changed them on a SII RX-7 and a Gemini, and had no dramas or needed any special tools...
Edited by SHY 33
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
