Group Buy 19 has been submitted as planned...
Next Group Buy 20 starts now until Wed 3rd Oct 07, with delivery expected between 5th-10th Oct 07...
  • Replies 490
Posted Images
Hi,
Can you please advise the price of EBC green stuff pads for the front and rear of an r33 GTST, front redstuff for an r34 skyline.
Thanks
Shaun
Hi mate, I know the rear is interchangeable with R33 Gtst but do you know if the front one is?
If you're not sure I'll check EBC part no tonight and see if I can get a match.
Cool can you do that and PM me the prices as i will need these very soon.
So that would be
R33 green stuff front and rear and
R34 Red stuff front pads
Cheers
Shaun
There's a couple of discussion and look like the R34 GTT front pads could be the same one used in R33 Gtst,
it's just the caliper is positioned differently to accomodate 310mm rotors on R34 GTT compared to the 296mm rotors on R33 Gtst.
The thread is in here: http://www.skylinesaustralia.com/forums/in...+GTT+brake+pads
and
unfortunately no exact part number was mentioned so I have to find out more first just to be on the safe side.
just wondering when group buy 19 things will be delivrered?? what day should i expect them
thanks
as mentioned before would be between friday to wednesday...
they've already process the order as my account had been charged for the bulk order so it should get there from monday onwards, if you haven't got it on friday.
Hi,
Can I please have a quote for EBC green stuff pads for the front of an R33 GTST and EBC black stuff for the rear of an R33 GTST.
Cheers
Kelz
Will there be another group buy after? I don't think i can have the cash by the 3rd, only just saw this group buy! :D
Perhaps there will be, but recently orders have been dropping in so this may not last forever if I don't get enough numbers/interest in.
GB 20 orders in so far:
- Adz2332 for r33 rotors (payment cleared)
- Phatlavish for r32 rotors (payment cleared)
- Kroozin for r33 brake pads (waiting for payment to clear)
- shaunr34gtt for r32 front rotors & ebc red pads (waiting payment to clear)
- djr81 for r32 gtr rotors (waiting for payment to clear)
quote sent...
update to GB 20 orders in/payment so far:
- Kroozin for r33 brake pads (payment cleared)
- shaunr34gtt for r32 front rotors & ebc red pads (payment cleared)
- djr81 for r32 gtr rotors (payment cleared)
- intune for r33 gtr rear rotors 7702S (waiting for payment to clear)
- heslo for r33 gtst rotors (waiting for payment to clear)
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
