Group Buy 19 has been submitted as planned...
Next Group Buy 20 starts now until Wed 3rd Oct 07, with delivery expected between 5th-10th Oct 07...
  • Replies 490
Posted Images
Hi,
Can you please advise the price of EBC green stuff pads for the front and rear of an r33 GTST, front redstuff for an r34 skyline.
Thanks
Shaun
Hi mate, I know the rear is interchangeable with R33 Gtst but do you know if the front one is?
If you're not sure I'll check EBC part no tonight and see if I can get a match.
Cool can you do that and PM me the prices as i will need these very soon.
So that would be
R33 green stuff front and rear and
R34 Red stuff front pads
Cheers
Shaun
There's a couple of discussion and look like the R34 GTT front pads could be the same one used in R33 Gtst,
it's just the caliper is positioned differently to accomodate 310mm rotors on R34 GTT compared to the 296mm rotors on R33 Gtst.
The thread is in here: http://www.skylinesaustralia.com/forums/in...+GTT+brake+pads
and
unfortunately no exact part number was mentioned so I have to find out more first just to be on the safe side.
just wondering when group buy 19 things will be delivrered?? what day should i expect them
thanks
as mentioned before would be between friday to wednesday...
they've already process the order as my account had been charged for the bulk order so it should get there from monday onwards, if you haven't got it on friday.
Hi,
Can I please have a quote for EBC green stuff pads for the front of an R33 GTST and EBC black stuff for the rear of an R33 GTST.
Cheers
Kelz
Will there be another group buy after? I don't think i can have the cash by the 3rd, only just saw this group buy! :D
Perhaps there will be, but recently orders have been dropping in so this may not last forever if I don't get enough numbers/interest in.
GB 20 orders in so far:
- Adz2332 for r33 rotors (payment cleared)
- Phatlavish for r32 rotors (payment cleared)
- Kroozin for r33 brake pads (waiting for payment to clear)
- shaunr34gtt for r32 front rotors & ebc red pads (waiting payment to clear)
- djr81 for r32 gtr rotors (waiting for payment to clear)
quote sent...
update to GB 20 orders in/payment so far:
- Kroozin for r33 brake pads (payment cleared)
- shaunr34gtt for r32 front rotors & ebc red pads (payment cleared)
- djr81 for r32 gtr rotors (payment cleared)
- intune for r33 gtr rear rotors 7702S (waiting for payment to clear)
- heslo for r33 gtst rotors (waiting for payment to clear)
Guest
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
