hey!!! (ive made this topic everywhere.. but i shouldve done it here coz of the head im using)
bloody hell had to remake another account because i forgot my username, but hey I own a vl calais turbo and im just about to put a rb26/30 into my car..
the motor is out at the moment (i bought it off someone else who also had a vl) and just before i put it in my car i need to know what to do....
previously the engine was running off a microtech ltx12s (or lt12s if its the same shit whatever lol) and the car is still in its run in tune, at 10psi.
so having said this i could get the ecu off the guy aswell, and plug his into my car and away i'd be.
he also has a decent coil setup. but id probably give him my motec m4 and i'd pay less for the engine or watever ("cash adjustment")
now my dilemma.
im really confused and i have nfi what to do with my Motec m4 (which i still own)... it sez on their webpages etc that it can run upto 4 ignition drivers? then people said what u do is batch them or whatever..... but it wont be as good as the lt12s coil setup or whatever...blah blah
well this is what ive been told so far -
you can run a Motec 'ignition expander' (runs up to 8 coils) and use batch or semi seq fire for inj, no probs
Or if you want / like CDI ignitions, use the motec CDI-8 module, easy as. both of these interface directly with the M4 ecu.
and then..
"As trev and shazza said, if you dont wanna run the expander, just run wasted spark instead of sequential, with 3 Bosch coil packs and you'll have an ignition output spare.
I dont know who told you that batching them will make idle bad, but its totally not true if its tuned correctly. It just means that the coil fires during the power cycle of two cylinders, rather than just one"
i am soooo confused and dont know what to do ay.
all i know is i gotta buy atleast an "ignition expander" for 330bux or i could pay nearly 2grand for some CDI bs... which seems shithouse coz thats too much.
what do yas reckon is my best option.. go for the ecu which is good enough and is aleady tuned etc (microtech) or go the motec way???????
big thx.
ps - dont tell me to speak to my tuner lol, i will but its a public holiday on monday, so they wont be open and i NEED TO KNOW WHAT TO DO ASAP!!!!!
Edited by gnki'vlct
https://www.sau.com.au/forums/topic/158999-motec-m4-multiple-coils/
I would get a set of EL falcon ignition coils and run wastespark, there is no problem with wastespark, as heaps of factory and high performance cars run it. Set your dwell time to 4ms. If down the track you find that you need more spark grunt, you can easily fit a 4 channel cdi unit($600)and the coil block which is quite neat is about $120 brand new from ford. The coils even have the cylinder numbers already marked on it to make it easy to hook up the coils to the spark plugs.
Just to clear a few things up wasted spark fires 1 cylinder on the compression stroke the other on the exhuast stroke.
4ms of dwell at 13v is a fair amount I would probably run around 2.5ms - so you dont burn coils out.
Wasted spark is not what I would be worried about. Its the batch firing of the injectors that I would be most concerned about if it is to be a street car. However the microtech in sequential mode is probly a little bit better than the motec in batch fire and its allready setup and tuned so I would be leaning on going down that path.
so how much will i need on the side to spend???
get 3 coils? theyre 50each.... then the motec ignition expander? would this be all i need to spend? (the car will probably be making around 400-450rwhp and thats through an auto transmission)
coz im pretty tight atm... lol and this pisses me off all these things about "batch firing" and "sequential"...
*sigh* wish i wouldve just bought an m600 from the start
Edited by gnki'vlct
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
