  • Replies 665
forgot this link...
:blink:
Look - I realize were a long way from Mexico so I'm feel it is my duty as the sole representative of North America and past resident of that country to point out to you several facts:
1) They only put worms in sh*t tequila to sell it to tourists
2) No one eats the worm
3) No one does shots of good tequila
4) Tequila must be followed by a beer chaser
Oh and one other thing thats pretty important that everyone should know...............ALWAYS give Smoky a huge :) when he's driving on the skidpan ;)
:thumbsup: dont be suprised if you get the universal signal in return :P
Ok.............so only one person used the ID box.........that was evilweevil - can anyone still waiting for confirmation please PM me what you wrote on the trasfer so i know who's money is who's?
Cheers
I did!! :huh:
Hey all you Welshies,
Just a couple of important things.
1. CAMS Licenses. If you do not have one we can sign you up for one on the day. All you will need is your Club membership card (you'll need this even if you already have a CAMS license anyways). You can then either provide a credit card number or give us the $$$ (I think it's $89 this year) and we can give you a 30 day temp license and send off your forms to CAMS for you.
2. Entries. The entries for Victorian participants open this Friday. Last time entries opened at 10:14am and all 50 spots were taken by 12.01pm. Thats 1hr 47mins. So - if you want to come to this event let Steve know before Friday or you will miss out. If you don't believe me here is the link to the last DECA event in Vic. http://www.skylinesaustralia.com/forums/in...howtopic=151753
For those that are coming here is the link for the Vic one for this time around. http://www.skylinesaustralia.com/forums/in...howtopic=164163
If for some reason your name does not appear on the list when Scotsman updates it and you have made arrangements with Steve before Friday to say you are coming please let me, Scotsman or Steve know ASAP. I will try and get Scotsman to post up the NSW entries before the Vic ones open on Friday.
For those that are coming - you better start practising those handbrake turns. :)
Made a Revolution Racegear run this morning. New helmet, fire extinguisher and a 4 way, 3 point Sabelt harness. Not the big buck stuff but should work well enough for my purposes.
Getting stoked for this....
but us NSW guys spots are secure yes??????
I dont want to get down there and find out we arent!
Steve - yes :P
jhahahaha
few secret spots up here!
All people who had contacted Steve before Friday and said they were coming ARE secure in getting a spot.
Cheers.
Hi all
Just found out you guys were coming down for DECA
Thats fantastic. You guys and girls will have a great time.
Feel free to pop in to the Vic forums and say Gday and get
To know the names of a few people before you all get there.
Im Wayne (RCHOO) anyway. I will pop in and out of here over the next few weeks .
And will have a beer or 6 with ya all when we get there.......... Cheers
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
