  • Replies 665
You almost had me? You never had me - you never had your car... Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake! You almost had me?
81 days to go
You love me!
I love lamp :blink:
81 days to go
Doesnt matter if its an inch or a mile!!.. winning's winning!! :laugh:
81 days till BTR (Beer Tossers & Retards) bow down to Team Wang Racing!! :D
I love lamp :blink:
OMG! 81 Days :sorcerer:
Sif BTR stands for that :laughing-smiley-014: :laughing-smiley-014:
LOL :laughing-smiley-014:
that doesn't make me wanna eat wang burgers
how's this
OMG thats so cool, I lol'd hard :rofl:
bahahahahahah roflcopter x 11ty!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Smokey - come on dude, we'll be team gun metal :D
Aww I can join that team!!!
:P - Dont worry about them Smoky - Team Wang will take you in
Yeah im sure Smoky would love to take some wang :rofl:
One more comment like that and you're walking to DECA....
He has no licence so he's walking anyway :thumbsup:
True!!.. Hows about Team Gun Mental?! :thumbsup:
What about my car TJ?? :huh:BTR.. the team for retards!! :rofl:
Oi thats not very nice!
I am so in Team Gun mental! :P
Yeah im sure Smoky would love to take some wang ;)
He has no licence so he's walking anyway :)
He will in 3 weeks...Booooyyyaaaahhhh! :sorcerer:
What about my car TJ?? :yes:BTR.. the team for retards!! :D
Sure it's not a myth?
I want to see you riding dude. If you don't then Andrew rides with Jess and I'm running empty. I don't have the Chubster's sexual magnetisim to attract hottties to ride with me...
bahahahahahha
that is one of the funniest things Ive read all day!!! :D
lol x 11ty
I just got an mms from Corinne with the sticker on her car - looks good!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
