I'm only looking for one reversing light switch.
I will see what i can do,as i will ba doing a manual conversion down the track...
maybe a R31 or 240k switch will fit??
I do know of one spare switch, i will ask its owner if it will be available
  • 4 weeks later...
  • 1 month later...
this might sound weird but i just need the heater control knobs. Ive lost a couple and need to put some back on.
:laughing-smiley-014:
how $70 sound? i mean i will keep them aside for you... ( 4 wen you pic up the power steering stuff)
Ta muchly.
just another quick question.. with the power steering stuff, will i be getting the steering box, pump, bracket and hoses??
Like the full kit?
yeah mate, my Blue MR30 is in really good running order, and if it does give way one day i'll just buy another car for parts!
the whole setup is still there, all bolted up... i havent checked it for leaks etc, but i did drive it 200km and there werent any problems then!
theres also a few pipes that run across the front of the aircon condensor, i guess thats to cool the PS fluid.
I dont have air con. Is this gonna be a problem? Or will just be able to bpass it?
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
