For information of members and guests Unique Auto Sports have recently moved to Unit 1 No 20 Tucks Road Seven Hills. Phone 02 9620 9000.
We bought the place here and have done it up nice over last few months. The out goings are half repayments compared to the cost of renting where we were and we will own it one day. Also lots of our suppliers are over here and lots of motor sports workshops, fabrication shops and machine shops for us to work with. It is fast becoming the centre of performance workshops etc for Sydney.
Our new location and building is a nice set up and great for dyno days as lots of parking and most other businesses around here are not open on Saturdays. Dyno room is not finished yet but operating and will be awesome when finished. With twice the fan extraction as the last one, and much quieter as has big exhaust collector and sound absorbing insulation in ducting up to the big three phase fans on the roof. The dyno room will be all sound insulated also.
We believe we will be more efficient here and offer better service to support SAU members.
https://www.sau.com.au/forums/topic/159465-uas-have-moved/
I've been out there and have to say I think it's pretty good. it may be a little further but it's MUCH more convenient to get to. literally 2 mins from the end of the M2 (or the end of the M7 depending on which way you come from). workshop is a much more usable space too. Now, get the whole place air-conditioned!
https://www.sau.com.au/forums/topic/159465-uas-have-moved/#findComment-2960424
Are you guys using the dynos in the evening/at night, John? I know MazSport is in Seven Hills too, but I also know that what I've been hearing over the past two weeks aren't rotaries!
I live literally right on the other side of the water catchment area behind UAS, so I'll be heading in there soon to get some things sorted on my car...
https://www.sau.com.au/forums/topic/159465-uas-have-moved/#findComment-2962306
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
