I can get a brand new set of gt2860r turbo's for my r33 gtr vspec for a good price!
Has anyone had any experience with these turbo's before???
What are they like??
It's for a street car so i need some response still???
Any thoughts would be handy!!
Thanks
https://www.sau.com.au/forums/topic/159854-would-these-turbos-be-ok/
yep just put some on my R32 GTR
feel great just a little bit lagger than stock R32 units but push really hard.
Only thing that didnt fit was the oil drain fitting on bottom of turbo so the bolt holes need to be slotted to fit.
Noone,
Fairly self explanatory, tis when you need it to fit, but cant be F'd or don't need to make a new bracket... so you drill / file out to fit
Scuze paintshop work
Are you sure that was all the issues? I had a mechanic describe a whole list of issues putting these on - of course I can't remember the specifics.
I see you're in canberra - did you do it yourself, or get some place to help you out?
Edited by cash0
Yer I just fitted them to my 32 as well. It's a big job but yes they do bolt straight up and the only modification is to slot the oil drian holes. It does seem alittle dodgy but but there's no presure in these lines so it's perfectly ok to slot the holes. I'm having other issues with mine at the moment though with "shuffle", mainly because I haven't got the necessary supporting mods yet and it's not tuned.
there are more "tricks" than "issues" when fitting them. Many green gtr mecahnics struggle with removing and fitting the turbos ie taking like 2 days to do the swaps....
Edited by URAS
Thanks
They are a direct bolt on....which type do you have..-7,-5,-10?????
Each are different.
Okay havn't had my turbos off YET so wasnt sure just thought drain holes would be threaded, slotting seemed like it could result in leaks I am assuming that isnt the case.
These sound like the go though little bit more lag than stock but capable of heaps more up top with the 2860 -7
and abit more lag than "-7's" with heaps more up top for the 2860 -5's
Just to clarify can I make a bracket change lines to avoid the need to slot the holes? Is there any point avoiding it ie. does it leak or anything if u do?
Edited by noone
its a common mod, if you cant master this simple task without disaster it would probaly pay to get some-one to install the turbos for you. trust me you should be fine.
thanks for your help as I stated havnt yet taken turbos off YET so am just more than anything wondering if these holes are threaded etc. think I can probly make a bracket OK or slot the damn holes "without disaster" I just assumed at first read these holes would be threaded for the oil return lines yet others have stated they elongated the holes was curious as i thought you would have to get a good seal so as to not have oil going everywhere guess not.
These sound like the go though little bit more lag than stock but capable of heaps more up top with the 2860 -5
and abit more lag than "-5's" with heaps more up top for the 2860 -7's
believe that
-7 is GTSS size
-5 is 2530 size
therefore you'd get more lag from a -5 than -7 but more top end for -5.
PS, byebyev8, big threads on these turbos if you search
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
