Guys, how do I tell if a certain turbo is suitable for my car? I have an R32 GTST & have recently purchased a t3/t4 turbo, being told it was a bolt-on item. Now realisisng it is not, I'm starting to wonder how suited it is to my engine. Has anybody tried or seen this engine/turbo combination before & with what results? I am wondering if I should spend the money modifying it to fit or resell it & spend the extra on a Sliding highflow. This is my 1st turbo upgrade. Thanks
https://www.sau.com.au/forums/topic/159866-right-turbo/
laggy, dinosaur components and problaby has some difficult flange/dump pattern. sounds like a lot of stuffing around. the factory unit is ball bearing oil & water cooled. you would be silly to change to anything less
https://www.sau.com.au/forums/topic/159866-right-turbo/#findComment-2969182
So apart from the ceramic wheels, my stock turbo is better than what ive got? Thank you very much for your help mate
https://www.sau.com.au/forums/topic/159866-right-turbo/#findComment-2969197
well its probably older spec bush bearing so it wont have as good response
sure it might make more power but could make the car a pig to drive
without knowing the specs of the unit its all guess work and hope for the best type outcome. there are plently of off the shelf ball bearing units for the rb20 that you can use, with proven results
https://www.sau.com.au/forums/topic/159866-right-turbo/#findComment-2969229
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
