I've noticed this for a while now, when putting the power down around a corner, the car would rev a touch higher and would jerk around. I am not breaking traction, nor am I going sideways.
It almost feels like the clutch is slipping, but I've had that replaced about 1000km's ago with a ceramic plate jobbie, that fixed up old mr slippery-launch!
Now when driving, changing lanes while putting the power down, the car flicks-back into the other lane quickly, almost like I'm recovering from traction loss.... But i'm not.
I put the car up on jacks (the entire rear-end) and noticed how the wheels spinned when i turned them manually.
I can turn the wheels in any direction and the other wheel will follow suit SLOWER. I can also hold back one wheel while I turn the other. The drive shaft is still turning when I hold one wheel back.
It is obviously a touch stiffer when I hold one wheel back, but I can still turn it. I thought an LSD was supposed to force each wheel to turn the same etc ? and you can't hold it back ? (can you?)
I've recently replaced diff oil with Castrol LSX90 (the best stuff for LSDs apparently)
What is happening ?
What usually wears out on a diff to make this happen ?
How can it be fixed ? Can I just take it to a Differential specialist and tell him to weld it locked ?
Cheers Guys,
-Kym.
https://www.sau.com.au/forums/topic/15988-help-diff-problem/
mine does the same, im not to sure what it is... just how it feels like your flicking the arse end out but u haven't broken traction in the first place. I have a feeling that it was something to do with the 4 wheel steer. Thats a guess, but thats what I was pointing towards
Sumo
https://www.sau.com.au/forums/topic/15988-help-diff-problem/#findComment-327751
hah kym i have the same problem i think
well mine - the car kinda 'wanders' when i change lanes
think of it as high winds blowing the car and you can feel it slightly swerving in a way
sorry im not good at explaining
however, i wanna get rid of HICAS as problem is definately caused by it (HICAS warning light comes on regularly)
https://www.sau.com.au/forums/topic/15988-help-diff-problem/#findComment-331203
Guest Boxhead
from what i know, if your doing one wheel burnouts, its a open diff, which either means thats what it is in your car, which is un likely, or your lsd is going bye bye, myn gives bad feedback, makes horrible clicking noises, and chooses when it wants to do 2 wheel burn outs, ive been told it is on its way out, and some say its the way it is.. ohwell.. if anyone knows were to source cheap GOOD diffs, sing out
https://www.sau.com.au/forums/topic/15988-help-diff-problem/#findComment-331225
afaik the R33 GTST has a viscous LSD , not a mechanical as per a GTR.
Viscous relies on silicon gel to heat up caused by a different turning rate in the axles.
If the diff is a bit old , this may take time to react if it does at all.
The waving or lane changing is more related to w/alignment , tyre pressures , shot tyres or slack bushings.
What you have to realise is the hicas works in the same direction as the front wheels above 60kmh ( or so ) and only move by 1 or 2 deg anyway.
Cheers
Ken
https://www.sau.com.au/forums/topic/15988-help-diff-problem/#findComment-331232
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
