I've noticed this for a while now, when putting the power down around a corner, the car would rev a touch higher and would jerk around. I am not breaking traction, nor am I going sideways.
It almost feels like the clutch is slipping, but I've had that replaced about 1000km's ago with a ceramic plate jobbie, that fixed up old mr slippery-launch!
Now when driving, changing lanes while putting the power down, the car flicks-back into the other lane quickly, almost like I'm recovering from traction loss.... But i'm not.
I put the car up on jacks (the entire rear-end) and noticed how the wheels spinned when i turned them manually.
I can turn the wheels in any direction and the other wheel will follow suit SLOWER. I can also hold back one wheel while I turn the other. The drive shaft is still turning when I hold one wheel back.
It is obviously a touch stiffer when I hold one wheel back, but I can still turn it. I thought an LSD was supposed to force each wheel to turn the same etc ? and you can't hold it back ? (can you?)
I've recently replaced diff oil with Castrol LSX90 (the best stuff for LSDs apparently)
What is happening ?
What usually wears out on a diff to make this happen ?
How can it be fixed ? Can I just take it to a Differential specialist and tell him to weld it locked ?
Cheers Guys,
-Kym.
https://www.sau.com.au/forums/topic/15988-help-diff-problem/
mine does the same, im not to sure what it is... just how it feels like your flicking the arse end out but u haven't broken traction in the first place. I have a feeling that it was something to do with the 4 wheel steer. Thats a guess, but thats what I was pointing towards
Sumo
https://www.sau.com.au/forums/topic/15988-help-diff-problem/#findComment-327751
hah kym i have the same problem i think
well mine - the car kinda 'wanders' when i change lanes
think of it as high winds blowing the car and you can feel it slightly swerving in a way
sorry im not good at explaining
however, i wanna get rid of HICAS as problem is definately caused by it (HICAS warning light comes on regularly)
https://www.sau.com.au/forums/topic/15988-help-diff-problem/#findComment-331203
Guest Boxhead
from what i know, if your doing one wheel burnouts, its a open diff, which either means thats what it is in your car, which is un likely, or your lsd is going bye bye, myn gives bad feedback, makes horrible clicking noises, and chooses when it wants to do 2 wheel burn outs, ive been told it is on its way out, and some say its the way it is.. ohwell.. if anyone knows were to source cheap GOOD diffs, sing out
https://www.sau.com.au/forums/topic/15988-help-diff-problem/#findComment-331225
afaik the R33 GTST has a viscous LSD , not a mechanical as per a GTR.
Viscous relies on silicon gel to heat up caused by a different turning rate in the axles.
If the diff is a bit old , this may take time to react if it does at all.
The waving or lane changing is more related to w/alignment , tyre pressures , shot tyres or slack bushings.
What you have to realise is the hicas works in the same direction as the front wheels above 60kmh ( or so ) and only move by 1 or 2 deg anyway.
Cheers
Ken
https://www.sau.com.au/forums/topic/15988-help-diff-problem/#findComment-331232
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
