So..
Can we possibly kill off some of the sticky threads???? There's wayyyyyyyyyyyyyyyyyyyyyyyy too many - surely we can make a sub forum for the different area threads ie: Central Coast, Hornsby, etc to clear it up???
The place needs cleaning.... its DIRTY!
Somebody?!?!
Edited by d0p3y
https://www.sau.com.au/forums/topic/159954-can-we-kill-off-some-stickies/
<insert mother related 50 cent joke here>
ok... now just to make sure you understand...... you asked for it.
Your mother... wait.. no... this is waaayyyy too easy... i'm just gonna leave this up to yr imagination and the next time you wanna be funny... think it through.
the community shouldn't be subdivided, it's stupid that for every 5people that live in the same area there has to be a sticky thread for them.
If they live so close to each other they should stop being lazy asses and actually walk down the street to see them in person. If NSW has each suburb seperated then it will never expand.
this was one of the strongest argument for no sub-forums for this. and also an argument for doing away with the threads all together BUT there was complaining, so the threads were moved back and stickied by someone.
Do we need to start a thread to kill a thread...does not makes sense to me...so, everybody reads no one writes .. that is the go?...c'mon the ideea is to write as much as possible..without reading..statistics.
Lets everyone share something is worth sharing....
Cheers,
EUG...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
