was just talking with a mate and he assured me that no skyline (R32-34) came from the factory with a sunroof, but this just didnt sound right to me, although i have nothing to back it up, he said he did somewhere. anyone care to give me a final answer? :worship:
https://www.sau.com.au/forums/topic/160040-skylines-with-sunroof/
I have a R33 with a factory sunroof, and i've seen hundreds of others with a sunroof too. all look the same as mine, inside and out. Roof turret with part number for optional sunroof
May be he was talking about the GTR...I am preety sure no GTR were made with Sunroof "Body rigidity issue probably..." I have seen many R33GTS - R34GT with sun roof....but not R32GTS....maybe their just rare...
yeah, im just gonna keep on at him about this thing he has that says they never came from the factory like that. yeah i've never seen a GTR with a sunroof, i'm pretty sure they didnt, maybe thats what hes talking about, but he was telling me skylines in general never did, and he is as stubourn as all f*ck. so keep the posts coming, then we'll see what he says
was just talking with a mate and he assured me that no skyline (R32-34) came from the factory with a sunroof, but this just didnt sound right to me, although i have nothing to back it up, he said he did somewhere. anyone care to give me a final answer? :nyaanyaa:
Tell your mate to shove this original brochure image up his arse, case closed...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
