hey guys i went down to the JEM dyno day on yesterday heres my dyno sheet:
mods:
slide hi flow turbos
full exhaust
hks evc III @ 1bar boost
mines ecu
k&n hi flow panel
everything else is stock, what mods should i be looking at next? im after a street car with 300rwkw.
ive already got in mind a power fc, 600cc injectors and a bosch 040. would that do it? anything esle i could do to make it pick up quicker as its pretty laggy to me?
whats everyones recommendation? and how does the dyno look cuz all i know is its a tad laggy and i want abit more power .
thanks!
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/
how well is it tuned? being a mines ecu will suck the wang, you should get a programmable controller.
there is more top end to be had there as the afrs plummet to 10's thanks to the mines engineers.
if you had a stand alone or controllable ecu you could tweak that to hover near 12 afr and get some more power.
as a comparison we can see
http://www.skylinesaustralia.com/forums/in...st&id=85489
twin garrett 2560's which are the hks 2530 equiv, you can see it wakes up at 120kmh which is 4200rpm
yours doesnt seem to wake up until 5000rpm
another one
http://img181.imageshack.us/img181/5640/r3...yno0003abk9.jpg
twin hks gt-ss (with cams however)
you can see it ramps up quickly and has good midrange from 100km/h which is 3500rpm
your does seem laggy. what are the specs of the hiflow units ?
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2973069
Your need management/injectors/cam gear before you can say that its a laggy setup.
Those 3 things and more boost... then that would be a good comparo.
For what you have there, its about right considering your missing key parts
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2973081
dont knwo the specific specs, all i know was it was slide (on the forum) hiflow turbos and using garrett gt2860-9 exhaust wheels.
i guess that would explain the lag?
seriously, get your mind off the lag. Its a null point at this stage ;)
You dont have:
ECU
Cam Gears
Two key parts. I wouldnt bother looking much into it until you have these parts installed and the car tuned
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2973161
Exactly right.
2530's cam gears and a power FC.
The engine is built etc but at the time had stock cams.
I tunned it and it not very laggy at all considering the boost and how low it is (13psi)
The thing pulled like a train as you could tell by the flat power curve.
Thats an old set-up but similar to how yours could be with the right mods.
Got yourself a Power FC, cam gears and go from there.
BTW that graph belongs to the other GTR that was at the JEM day. Its mine.
Edited by Risking
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2973179
GTRgeoff is making 316rwkw on his R33 GTR at 1 bar that SelectMaz (Wayne) tuned with the same set of our highflowed turbo's.
That should be a good indication on the power you are missing out on by not having a tunable ecu like a Power FC.
Fitted turbos over the last couple of days. The usual stuff like wrestling with Nissans fine piping engineering (and it sux, my design is better on the RB25DETT/26-30TT). I'll replace it all in a year or so.
A visible difference in the size of the compressors and turbines.
Didn't have time to sort out the boost control so on stock GTR33 high boost setup of just under 1bar she pulled 316rwkw with sard 700cc injectors and PFC on a 31 degree day. Pulls like a 13yo with a porno mag. The tuners at SelectMaz, Wayne and Drew were quite happy with the result, Drew getting quite carried away with the amount of torque on road and Wayne blown away by the tractive effort on the dyno.
I'm happy as well and looking forward to getting the rest of the potential out of them when I don't have another engine to build and tune before moving to Brisbane next Friday.
Thanks Aaron.
The turbine is the Garrett T28 cropped race shaft with -5, -7, -9 compressor wheel.
I would have to search through the books to see which comp wheels were put in yours as we didnt have regular stock then if i remember correctly.
There is not too much difference between them.
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2973272
LOL, whats with dyno sheets that start at like 4500rpm. Doesn't anyone care whats happening below that? I drive under 4500rpm quite frequently.
ECU and tune will make a big diff! I just got full boost about 1000rpm low by adding an ECU and tune... different engine... but still..
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2974084
The fact that you are running a k&n panel filter (I guess in an otherwise stock box?), would be restricting the top end a bit. I suspect if you got pod-filter and cold air induction, there would be a fair bit of power gain there, and the power wouldn't start flattening out as soon.
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2974294
the GTR airbox is actually quite decent.
Having seen many a car rattle off over 350rwkw with the airbox, leads me to believe it cant be all bad
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2974364
Nothing wrong with the GTR air box besides the fact its a pain to work with. Ive also seen a few GTRs making 350 with it still fitted. power is not flattening off because of a restriction its flattening cause of the sheer ammount of fuel its swallowing!
GTR injectors will be fine for 300kw like his planning to run as will the MAF's
https://www.sau.com.au/forums/topic/160150-analyze-my-dyno/#findComment-2975704
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
