  • Replies 60
Chris, PM replied.
And cheers Taffrey.
Matt I like the Maximas, especially the Ti, but the boss has her heart set on a Subie. Cheers though! :) Happy to sell to you for cash! :thumbsup:
Mark
tempting...
ill be keeping an eye on this over the next couple months,
might be able to take it off your hands once i get my finances sorted (again...)
Cheers lads, all PMs replied.
Hopefully I'm home from work early enough tomorrow, so I can take (and post) a few underbody, interior, and engine bay pictures for those that asked to see them.
Mark
As a few blokes have been asking why did I respray the car:
When in Japan, some the sphincter of the universe at the caryard decided to forklift it around rather than drive it. Using the forklift crushed the outer sill panels and by the time the car arrived in Aus the panels were starting to corrode and were heavily damaged.
I bought new outer sill panels from Mr Nissan Japan and had a bodyshop fit them. As I was paying for the entire interior to come out for the sill panel replacement, I decided to go ahead and respray the car, replace the right rear quarter and rear quarter glass on both sides.
Hope that helps!
Cowie
Yes I did thanks, but I ended up buying Raw111's R33 GTR Vspec last weekend instead.
Good luck with the sale of your car though, its definatly a good buy.
Cheers,
Ian
I was really looking for a freshly rebuilt car, but this is a good price and the paint is great, so can you just tell me if the fluctuations of up to 10 psi (assuming psi is what was used to gauge) are big fluctuations or whether we're talking minor damage or we're factory condition (145 140 150 145 150 150)
It depends entirely on how the test was done. If it was done cold and dry as most people do them so they don't burn themselves, well the results are fine.
Keep in mind that an alloy piston grows in size when it heats up more than the engine block does, so ring seal and piston/bore seal improves with engine temp.
If these are the results of a wet test (tablespoon of oil in the cylinder to aid ring seal), then this might indicate an issue. In the scheme of things 10psi is nothing.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
