IM SELLING THIS STUFF BECAUSE I NEED TO FUND NEW TYRES. MOST ARE BRAND NEW. PICS ARE AVALIBLE FOR ALL PRODUCTS JUST ASK. PRICES ARE NEGOTIABLE DONT BE AFRAID TO ASK FOR PICS OR DISCOUNTS. LOCATED IN WESTERN AUSTRALIA.
EMAIL: [email protected] FOR MORE INFORMATION
I have 2 air flow meter adapters to fit all skylines, 180sx, 200sx, 300sx, and others $20 each
-Boss Kit $40
(for r32)
-Tachometer $20 posted
(Retails at $57)
-Pod Filter, Heat Shield and Small Chrome Pipe $35 posted (PENDING PAYMENT)
(Good Setup if looking for a Pod Filter)
(Retails at $70.98)
Saas Steering Wheel $80 posted
-Gauge Cup 2" $5
-MONZA Breather Valve $5
-Missle Switch $5
TOOLS:
-HSV 1/4" Drive 27 piece Socket Set $80 (Brand New) posted
(Lifetime Warranty, Limited Edition Shadow Chrome, One AWESOME Kit)
(Retails at $160)
-Superworks Gold Tools $30 posted (Free with HSV tool kit)
(Three Tools, Lifetime Warranty)
(Worth Over $50)
-Impact Driver $10
AUDIO:
-Aerpro Stereo Transmitter $30
(7-CH FM, 7-Freq Controls)
-Distribution Block $10
(1x4GA to 4x8GA)
-50 Amp AGU Fuses x5 $5
-Platinum Fused Distribution Block $20
(1x4GA to 2x8GA)
-Platinum AGU Fuse Holder $10
-MP3 Player With Recharable Battery Kit $70
(4xAAA 6xAA and Charger)
(Retails at over $140)
(ALL AUDIO EQUIPTMENT LISTED $80)
PAINTS:
-Tail Light Lense Paint $10
-Bright Chrome Paint x2 $10each
MISC:
-Digital Engine Analyzer $20
-TFT Windshield Remover $10
-Automatic Solar Power Controller $20
(12VDC 5A 60W)
(Retail at $69)
-In Tank Fuel Pump $40
(Suits Fords)
(Retails at $169)
-Breathelizer Pro2 $60
(Brand New, Comes With 8 Plastic Tubes To Blow In, Very Accurate)
(Retails at $170)
SPARK PLUGS:
-NGK Spark Plugs x5 $50
(BKR6EIX-11)
-NGK Spark Plugs x2 $20
(BKR6EIX)
IN TUBE THINGS:
-Exhaust Cement x2 $10
-Gasket Goo $5
-Tailpipe Sealant $5
-Metal Filler $5
Edited by blinko
https://www.sau.com.au/forums/topic/160451-fs-heaps-of-stuff-check-it-out/
PERFORMANCE:
-MONZA Blow Off Valve $50
(Retails $149)
-Oil Cooler Kit $60
(2L or Under)
(Retails $119)
-Tachometer $20
(Retails at $57)
-Neons 2pcs Blue $80 (Pickup Or Delivery Only)
(75cm, 64Leds, Water Resistant, 11 Diff Patterns, Contrller)
(Retails at $159)
-Speco 4" Tacho $160 $150
(With Shift Light)
(Retails $245)
-LED Digital Turbo Timer $60 (Brand New)
(With Batery Voltage Display)
(Retails at $110)
-Pod Filter, Heat Shield and Small Chrome Pipe $30 (SOLD PENDING PAYMENT)
(Retails at $70.98)
-Gauge Cup 2" $5
-Missle Switch $5
TOOLS:
(Retails at $160)
(Worth Over $50)
-Impact Driver $10
AUDIO:
(1x4GA to 4x8GA)
(1x4GA to 2x8GA)
ENGINE DRESS UP:
-Intercooler Clamps x 2 $10
PAINTS:
STOCK R32 PARTS:
-Stock R32 Skyline Stearing Wheel $80
(Excellent Condition)
-Stock R32 Air Filer Box $40 (Pick Up Only)
MISC:
(12VDC 5A 60W)
(Retail at $69)
(Suits Fords)
(Retails at $169)
-Breathelizer Pro2 $70
(Retails at $170)
SPARK PLUGS:
(BKR6EIX-11)
(BKR6EIX)
IN TUBE THINGS:
-Gasket Goo $5
-Metal Filler $5
How much shipping of steering wheel to Victoria?
$15 would do it.. but i havent actually taken it off yet and i dnt know if it is coming off soon.. i went to take it off today but it looks like sum1 sold me the wrong boss kit.. so yeh
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
