hmmm.. looks like he has his own software too!!
I'm not sure I would want to trial it though.. probably a bit dodgy :D
When you install him does he run around the room in circles doing and ignores what you tell him to do?? till you click the "purchase" button... ?
  • 3 weeks later...
