HEy guys
After having a serious think i have come to a conclussion to sell my R33 as i am moving to qld in 2 weeks and i am not going to have anywhere to park it there and some c*nt would probably steal it if it was parked in the middle of brisbane.
Details
Car Details
PRICE 25kono :laugh: well over 30k spent on it,
NEEDS TO BE GONE IN 2 WEEKS. So if someone want it get in fast!
Cheers
Alan
https://www.sau.com.au/forums/topic/160532-r33-forsale/
HEy guys
Details
Car Details
PRICE 25kono :) well over 30k spent on it,
Cheers
Alan
oh no Alan, don't do it. :sleep:
https://www.sau.com.au/forums/topic/160532-r33-forsale/#findComment-2981895
People needs to go. $24k. I could not even replace all the parts that i ahve put on it for 24k!!! IF somone wants it the better be fast cause it might be going on Monday to the dealer!!
buy a falcon c'mon, just put it on the boat
https://www.sau.com.au/forums/topic/160532-r33-forsale/#findComment-2986309
i wouldnt rush to swap it if i were you mate, itll cost you thousands :rofl: . if i were you id wait till your 33 is sold,then get the herald, find the cheapest price on a typhoon in there(theres so many dealers over there they have specials on them all the time), tell tilford or jackson or where ever you want the typhoon from and get them to match/better the price :rofl: ... if your gunna loose 4-5k of the sale price(of your 33 in a trade) your better off trying to sell it private for 1-2 or so thousand less :rofl: .
just read the evo9 bit :rofl:, same rules apply
Edited by toffy
https://www.sau.com.au/forums/topic/160532-r33-forsale/#findComment-2987362
63k on Road. All i can say is there is alot of money in brisbane for the work it do!!!
Congrats on the new toy Allan, sorry to see the line go and that it wasn't replaced with another nissan :stupid:
What the hell do you do for a job and when can i start :happy:
https://www.sau.com.au/forums/topic/160532-r33-forsale/#findComment-2994586
The only other nissan it would have been replaced with would have been a R34 GTR. But kowing my luck with skyline i would spend a bucket load on that. So the new Evo 9 is going to be fun!
For work I do Civil/ Structural Engineering Design/ Drafting.
https://www.sau.com.au/forums/topic/160532-r33-forsale/#findComment-2994593
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
