Hey there
I have a Silvia with an rb20det in it
Currently one of my coils - second from the back is overheating/melting
and is NOT sparking either.
---It sounds like a WRX-----
What would be wrong?
We have tried a range of new rb20 coils and checked the spark plug and all are fine :sleep:
any help would be appriciated!
cheers
sammy :)
https://www.sau.com.au/forums/topic/160550-coil-help-my-rb-sounds-like-a-wrx/
could be a dead CAS, although im not sure if its capable of making only 1 not work.
it could also be your igniter pack (again, im not sure if rb20's have them).
then again, it could be a cracked ring/land. get a compression test.
* she lol
we have bought some coils and tried them,
however is it possible that red top and silver top coils are different???
cause despite the fact that we bought 'rb20' coils - they are not exactly the same as the ones in the car.
Red top and silver top coils are totaly different. Just to give you an example, Red top coils fit onto the CA18DET and vise versa. Silvertop coils only fit the Silvertop.
Try getting the right coils, if thats not the problem, then change the igniter (the square thing ontop of the cover) And take that cover off! it traps heat under it and melts coils.
A dodgy CAS wont make one coil not fire, if its the CAS it wont start at all.
Edited by Rancher
Hey there
We have tried a range of new rb20 coils and checked the spark plug and all are fine :)
cheers
sammy :(
My car has the same problem at the moment it sounds like a outboard motor.
Ive been told it is a temp sensor fouling the plugs?????????
coils are different from the ignitor pack. its the black box that sits at the rear of the engine above the coils
yeah i know, i swear i read it as coil packs when i was replying :( . must have been in another world.
sorry mate.
  • 5 weeks later...
Hey my car is having the same problem i have a s2 r33 and have put splitfire coils, new plugs in, a new cas and the ecu looked at i am going to try a new ignitor pack if this doesnt fix it is there anything else i can try. Cheers
mine did the same thing (rb25) replaced the ignitor pack and all was good but then few days later fryed another ignitor pack turned out to be a dodgy coil that kept frying my ignitor so i replaced with splitfires and bought a 3rd ignitor and all is well now
if you have a series 2 they dont have a ignitor pack, are you sure you got the right splitfire coil packs? as series 1&2 are different
Yea i realised that after i posted it lol. I have only had the car a while and it had them when I got the car and it ran fine and have been told the coils where ok by two diferent shops but i will check agaian anyways thanks.
  • 1 month later...
Hiya,
First of all, redtop coilpacks are different from silvertop ones.
Second of all, I think you should double check the wiring into your ECU. Especially since you've done an engine conversion, it's very likely a wiring issue. Look up the wire for cylinder #6 and double check its the right wire for power to that cylinder.
I had the EXACT same issue with my car (RB20 into an R31) and it turned out that the coilpack wire had been spliced directly into the temp sender. The result was a constant signal to the coilpack which melted it. Not fun and not cheap.
Good luck, let us know how you go.
Edited by R31vhead
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
