Hey there
I have a Silvia with an rb20det in it
Currently one of my coils - second from the back is overheating/melting
and is NOT sparking either.
---It sounds like a WRX-----
What would be wrong?
We have tried a range of new rb20 coils and checked the spark plug and all are fine :sleep:
any help would be appriciated!
cheers
sammy :)
https://www.sau.com.au/forums/topic/160550-coil-help-my-rb-sounds-like-a-wrx/
could be a dead CAS, although im not sure if its capable of making only 1 not work.
it could also be your igniter pack (again, im not sure if rb20's have them).
then again, it could be a cracked ring/land. get a compression test.
* she lol
we have bought some coils and tried them,
however is it possible that red top and silver top coils are different???
cause despite the fact that we bought 'rb20' coils - they are not exactly the same as the ones in the car.
Red top and silver top coils are totaly different. Just to give you an example, Red top coils fit onto the CA18DET and vise versa. Silvertop coils only fit the Silvertop.
Try getting the right coils, if thats not the problem, then change the igniter (the square thing ontop of the cover) And take that cover off! it traps heat under it and melts coils.
A dodgy CAS wont make one coil not fire, if its the CAS it wont start at all.
Edited by Rancher
Hey there
We have tried a range of new rb20 coils and checked the spark plug and all are fine :)
cheers
sammy :(
My car has the same problem at the moment it sounds like a outboard motor.
Ive been told it is a temp sensor fouling the plugs?????????
coils are different from the ignitor pack. its the black box that sits at the rear of the engine above the coils
yeah i know, i swear i read it as coil packs when i was replying :( . must have been in another world.
sorry mate.
  • 5 weeks later...
Hey my car is having the same problem i have a s2 r33 and have put splitfire coils, new plugs in, a new cas and the ecu looked at i am going to try a new ignitor pack if this doesnt fix it is there anything else i can try. Cheers
mine did the same thing (rb25) replaced the ignitor pack and all was good but then few days later fryed another ignitor pack turned out to be a dodgy coil that kept frying my ignitor so i replaced with splitfires and bought a 3rd ignitor and all is well now
if you have a series 2 they dont have a ignitor pack, are you sure you got the right splitfire coil packs? as series 1&2 are different
Yea i realised that after i posted it lol. I have only had the car a while and it had them when I got the car and it ran fine and have been told the coils where ok by two diferent shops but i will check agaian anyways thanks.
  • 1 month later...
Hiya,
First of all, redtop coilpacks are different from silvertop ones.
Second of all, I think you should double check the wiring into your ECU. Especially since you've done an engine conversion, it's very likely a wiring issue. Look up the wire for cylinder #6 and double check its the right wire for power to that cylinder.
I had the EXACT same issue with my car (RB20 into an R31) and it turned out that the coilpack wire had been spliced directly into the temp sender. The result was a constant signal to the coilpack which melted it. Not fun and not cheap.
Good luck, let us know how you go.
Edited by R31vhead
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
