recently a friend of mine recommended i use copper spark plugs - because apparently they are a better conductor . but with the fact that they have to be changed every 5,000 kms. anyway i set my self of to repco to pick these up . got home , set the gap to 0.8 , and installed them . now my friend has the sneaking suspicion that i have the wrong ones , for some unknown reason . preferably because of the model number - and hes worried that they could cause the car to run R & R in heat temperatures and cause misfire .. i havent noticed anything yet , but im worried it could .. eventually on a hot day or something or long driving - which i dont have the time to do ...
the plugs are champions , model no: rc10yx4
has anyone ever had these in there car . i know they are cheapies , but yeah apparently they work better because of the copper , better than the nkg , etc.
any one with any knowledge - please post , much appreciated.
cheers
https://www.sau.com.au/forums/topic/160551-spark-plug-trouble/
heat rating of 6 is the norm
Well normally on the ngk the heat rating is the number for eg. BKR5IX-11
So heat range 5 gap 1.1mm
But it should be 6 or 7
The best plugs is BKR7E V power ngk. already gapped at 0.8mm
So going by your plug ur heat range is only 4 but not sure with the champs/
Edited by subzeroR33
where did you purchase the $4 copper core ones ? BCPR6ES? .. when i purchased mine the gap was majorly small . left is a adjusted 0.8 . right is how they came .... for those who have many experience with spark plugs , i have another question ! after i installed and gapped to 0.8 , i noticed the car would have a slight bump every 2 -3 mins when warming up on idle .... is this the spark plugs or something else?
The BCPR6ES are the non-vgroove ones.
Also.. shop around you can get them for under $3 a plug. Motortraders/Coventry's (google it for the outlet in your area) do them for under $3, they also stock the BCPR6E plugs which most dont.
Autobarn stock the BKR7E plugs where as most others dont.
Yes.. My 7's (BKR7E) used to foul on the pfc's stock water temp enrichment table. I leaned it off quite a bit which stopped it. Car actually drove a fair bit nicer too, not as boggy feeling when stone cold.
I have no need for the 7's so next set I dropped in the usual BCPR6E plugs.
hmmm . when i took the old plugs out the gap was like 1.5 = huge ! - i might call up repco and ask what heat rating they are ... - im quiet annoyed about this , mainly installing them - its a pain in the ass removing everything to get to them
I find the NGK Cheap coppers are good for 20,000km's.
I pull them out and they still look fine but the gap at that point starts to grow.
30,000km's and they are pretty stuffed but still appear to drive fine. All rounded off big gap etc.
300rwkw odd and they will get chewed up a little quicker, depending on your driving style.
But still 20k from a set of plugs worth $17 total for the average line is perfectly fine.
Ripping the plugs out isn't hard nor does it take long when you have the tools sorted for the job.
It shouldn't take longer than 1hr to get a set of plugs in and out providing you have the tools for the job and organise yourself. :)
Last week I put NGk iridium ones in to my car since my one is RB25DE its already gapped to 1.1mm after I installed it next day I saw under the bonnet, sticker shows aprk plug gap should be1.05mm.......... :( damn!!!!!!!! should I change it back 0.05mm? or is it ok to run like this? my car is 1994 R33 GTS4 non turbo............
Cheers
Chinthana
should be ok that difference is so marginal you will not notice any difference, you start noticing a difference like me when you got a turbo and you hit boost and you missfire and then you need to gap them to get rid of it (1.1mm same as urs to 0.8).
It shouldn't take longer than 1hr to get a set of plugs in and out providing you have the tools for the job and organise yourself. :(
a full set of spark plugs of $17??? reali? thats wot im talking about!!! ;)
So i have a R33 GTST series to and i need to change the spark plugs, what brand / model should i ask for?? So i can just walk into a store in adelaide and say i want this......
cheers!!!
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
