The reason why i ask is that i just bought mine and it has aftermarket ones installed. There is, however, a proper button which they are wired up to on the dash...
I have looked at photos of other 32gtrs and have not been able to identify where the standard ones are...
:P
In short, no.
But they are not so uncommon.
I didn't think they did, so do you know what the button is on the right hand side of the steering wheel above the rotating thingy which turns on the headlights and parkers?
They don't, but anyway.
The most common spot for the foglights in under the top section of the front bumper either side of the number plate. Usually the mesh screen for the interccoler/radiator cut out gets a couple of holes cut into it to fit the lights.
Do you know where they normally sit?
They sit right in front of your intercooler, on both sides, small ones.
There is a switch on the dash, its for fog lights and amber lights. Do a search on the forsale section, there had been a few pairs forsale lately.
Oh they might not be standard but definately a standard option.
No, they're definately not standard, but may be an option (but I really don't think?)
The switch you're talking about allows the park lights to be on when depressed with the ignition key removed and the car locked (for when parked in a dark or dangerous position).
yes and no. the ones pictured are a dealer option available at time of purchase. they may have even been fitted at the factory, or if not fitted at the dealer when sold. but they are not standard.
  • 5 months later...
sorry guys.. i know this is an old post but i needed a bit of help. i was after some fog lights that would fit the spaces in my front bar pictured below. a pair would be nice but i dont mind just one and im after the really tacky looking yellow plastic covered ones.. any help would be great..
cheers, tushar
Why would you want to put fog lights in there? People usually leave it open for more air flow to the intercooler/radiator. If you want a fog light to be put in there, measure out how large the gap is and find a light to fit. I would assume it'll be hard finding some that fit perfectly though.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
