Im sceptical just as URAS is untill I can see correction figures.
Get them to run it up after the tune in shootout mode and make sure there are figures at the bottom like this one has.
Fairly easy to define a legit graph to a dodgy one then.
tell me what i need to ask for when he does it again on saturday, the HP figure means little to me but a safe AFR does.
Next time i will leave the arabic writting on the sheet so you can read that too :-)
yer i reckon i can ask him to do that thanks for the info
Edited by tacker
And another thing is with these turbos and no supporting mods you can expect bad compressor surge, as I've just found out! My GTR's barely drivable around town! So it looks like it's back into the garage for mine until I can afford the required extra's. :D
Well let me rephrase that.. just forewarning you... it's a possibility that you could end up with an undriveable car due to shuffle because of no supporting mods.
I have bugger all mods at this stage other than the usuals i.e exhaust, pods etc. No after market engine management (mines modified). One of my original turbo's shit itself and I plan to do quite a few mods later on and so wanted turbo's that will be up for it later on down the track hence the GT2860-5's (Never pulling them off again!! What a shit of a job!!!) And now have bad shuffle at cruise and low speeds.
Turbo's ,especially 2530(-5)or GTRS(-10) for a gtr need some mods.
1-Exhaust should be at least 3" right through...including CAT.(Air)
2-Fuel pump replaced to NISMO with regulator.(Fuel)
3-A tune is required with an after-market ECU.
You don't expect more power when the Engine is in a mild state of tune...do you?
How do you expect things work...get a Turbo('s) that is larger and assume the car will be better...wrong?
You made the right choice with the 2530's...you just have not been listening to what every-one is saying.
Get yourself an ECU and get a tune
hmmm i think i will wait till i get a powerfc and a pump and get the car tuned for low boost before i drive it then.
johnny
hmmm you have other issues, even though im no fan of 2860's i have fitted them to stockers b4 with no hassles in fact i just fitted larger T517Z's to my missus's RB26 powered silvia and it drives fine (no boost etc) of course it needs a tune but it would be safe as houses to go to shops and back....even as a daily commuter it would suffice until dyno time should present itself.. road tuning ruled out on this one....its a bit anti-social.
Yes i know and if you read my post properly it explains my reasons for putting these turbo's on without any supporting mods. JohnnyT originaly asked if his car would be ok with -5 turbo's and no supporting mods. And I'm simply saying that yes it will but he can't expect it to run properly..... like mine.
Hmm, possibly do have other issues, I didn't change anything other than a small amount of metal off the exhaust manifolds??
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
