I have the same turbo's.....I though the same as you.
The turbo's sounded like they were fluttering......but all is normal.
Get a tune and wait a little while.
I don't notice this anymore on mine..either the surges have gotten softer
or I have got use to them.
  • Replies 54
I'm curious how tuning can fix it too. I assume that the surge you guys are talking about is when you very slightly back off the throttle, it flutters and the car sort of shudders. my S14 does that too and i wanna get rid of it.
I believe the intake wheel of the Turbo slows down when you back your pedal off or change gears.
The excess amount of air is pushed back onto the incoming air it has tried to create.
Thus causing fluttering, the longer you drive around the softer this sound becomes.
the harder you push the car...the better the sound becomes
from my knowlege it occurs when the engine is on load and throttle is half backed off
so to me it sounds like the bov's are half opening so pressure is vented back into the front of the compressors
and some how causes it to either surge or vary excessively which gives the compressor flutter / chop chop noise
confused how tuning would fix it, even though it does
I don't think the tune actually fixed mine,it was their after the turbo's where fitted and tuned......and went away slowly.
Does the AVCR boost controller learn from excessive flutter and driver behaviour?
I have an AVCR boost controller...and seeing that it creates/controls boost it can also slow the spikes...maybe.
I wonder if the boost controller is controlling my flutter?
Just my 2c
i doubt it would tekin
i would be surprised if it would
most controllers are purely interested in build a good ramp for boost build and keeping it stable
im not even sure it would see the bouncing pressure
go for a drive and replicate it, let us know
does boost pressure bounce? i bet it doesnt
I am just trying to figure out why it has gone away on mine....
Are new turbo's tighter in the wheel construction?
Do you need to break in a Turbo....get it to loosen a little maybe.
Has anyone had this thing on anew turbo that has slowly gotten quieter?
Or is it as I had stated....you just get use to the noises...
actually it makes a bit of sense if it is seeing the pressure vary
cos then it would close and open its solenoid based on pressure
so the turbine would speed up quickly as the gate would close
then it would open again, like rapid chatter
try it and let us know if the boost varies rapidly (as in the controller display)
plot BOOST on analog chart display and see what it looks like
getting more air into the cylinder rather than having it revert should be the key.
changes to cam gears could/should help.
exactly why tuning beats me. i spoke to a few tuners that feel it can be difficult to get around but others seem to think it is no problem. so i imagine the degree of mismatch of the turbine/compressor wheels might make this easy or near impossible.
and these turbos are not mismatched.
Edited by wolverine
there is no such thing as wastegate flutter
remove the phrase, it does NOT exist, there is no such thing
im curious how the tuning can correct this
Ok so what do you call it when the wastegates go chu,chu,chu,chu and the car surges and carries on? please elighten me. I've already ruled out the BOV's as I said earlier.... I'm confused
Hey everyone, I just finished fitting the GT2860-5's to my R32 gtr and must say they've made a huge difference, the car feels more responsive and comes on boost earlier too. On full throttle it's fine but on really light acceleration and at cruise I now get bad waste gate flutter and surging. I never had this problem with the original turbo's and haven't changed anything other than the turbo's and a bit of metal off the exhaust manifolds.
Any ideas?? Help please!!!
Do you have a boost controller?
What make and model?
i dont understand how it can be a case of stuffing too much air into the cylinders
from what we know it happens when the engine is on some load (not max) and its up a hill
a hill usually brings on good engine load, which is great for boost building
but it happens when the user is on half throttle, not what i would call max throttle
at least, what i have read it occurs when its half throttle, and not max, is that correct?
paul this is exactly what i have experienced with an ordinary hi-flow of unknown origin.
light to medium throttle openings caused surge, WOT all good.
changes to tension of the BOV spring eased the symptoms, changes to tuning and cam gears cleared the issue.
its not the wastegate's fault, there is no such thing as wastegate flutter
its do with the bov's, i suspect they are half opening
and its causing a conflict with either the compressors or the actuators opening and closing rapidly
as pressure in the manifold varies rapidly
as simple as adjusting the duty cycle on the boost controller so its slow and progrssive would possibly cure it out
i suspect thats what most tuners do to correct it, make the solenoid open slow and in small increments instead of fast and hard
that way it doesnt induce open/close/open/close type behaviour, which dictates massive changes rapidly in manifold pressure
as the compressor is sped up and slowed down repeated really quickly
i also think there are two issues here (well maybe)
compressor surge of "fluttering" occurs when pressure past the compressor is beyond what the compessor can supply
ie:
workshop A hiflow and do whatever and you go and run the turbo
you dial in 15psi but forwhatever reason (mismatched combo, bad wheel, etc) then manifold pressure ramps to 22psi
the compressor wheel surge's as the pressure past the outlet is greater than what it can supply so it flutters/surge's
i would expect this problem to only occur at full throttle, wide open throttle and aggressive boost building / full load
the other scenario is the common after market twin turbo flutter / chuffing
which i think is a combo of the bov's half opening and venting back and then actuators opening/closing
in a harsh and on/off type fashion instead of soft and progressive.
this only occurs during light / medium load and usually up a hill is a good example of when it occurs
Hmmm, but I blocked the vacuum line to the BOV's off and tried it, and made no difference at all. And it's only on very light throttle right on the transition from manifold vacuum to boost that it occurs
The wastegate is located on the Turbine/Rear of the turbo
The surging is from the comressor wheel, which is on the Intake/front side of the turbo
Comp surge (the type we are talking about here) occurs when the turbos are flowing more air than then motor can handle
The air is coming from the compressor side, and has nothing to do with wastegate operation on the rear end of the turbo.
How it is tuned out, i am not sure. I'm yet to go across that in my travels
hmm well then im not sure
i cant see a reason why a new pair of turbo's would surge when going from vacuum to positive pressure
knowing what the tuners do to fix it could help give it away
maybe they just retard the timing a touch during boost build
that could help, but a bit of a poor mans fix maybe?
id love to know the cause
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
