  • Replies 119
don't think its got anything to do with which series you got... I get on average 390-450 per tank.
I also did Adelaide to Perth when I first bought the car and the best it did was 520 with an eighth of a tank lef and doing 120kms/ph... and I'm guessing that was on stock boost as some twit had disconnected the EBC.
I have
SAFCII
Greddy EBC
Metal Cat
3" cat back
always run on BP 98 Ultimate
toyo tyres
running on 10psi
And I have fun sometimes. its hard to stay off boost. :laugh:
my 1st choice of fuel was bp ultimate but of late i've been using vpower i think i'ts improved economy & possibly performance,regulary get 450 to 500 plus
I switched from bp ultimate to shell vpower a few months ago and noticed my car ran richer, and not as smooth. It was ok at first but eventually I figured my car just didn't run as well as with bp. So I've since switched back to bp ultimate and couldn't be happier. I basically just wanted the savings from the fuel dockets to get 4c a litre off with shell, but noticed that bp was often about 2c a litre cheaper anyway where I live. I'm not a fan of the whole fuel discounts thing - it just means they bump up their prices to accommodate it, and therefore rip off those that dont have dockets on hand...
In my experience bp gives better performance and just makes the car run smoother and generally better all-round.
Fuel economy was about the same on both, couldn't really pick any difference there.
I had my car tuned on bp ultimate - not sure if that would make a difference...it could have affected timing I guess, which at that stage was not advanced at all.
Edited by pixel8r
Yea me too. When i first got the car i tried 3 different fuel. Bp, shell and Mobil. I found mobil to be the best of all. It gave most power amongst the 3. My car was tuned on mobil98 . Ben from Rcepace gave me the option of using wither mobil or Bp and i chosed Mobil.After the tune i ran with boost 98 and i cant pick the difference other than the price.
With boost 98 with a/c pn 80% of the time mixed in city driving and HWY (30%-70%) im getting about 430-450km/tank). The car after tune is pumping out 236kw@wheels. So its not bad for the fuel consumption.
  • 6 months later...
i found with every car ive had that making sure ur engine is running as good as possible is the key to fuel economy. always check ur coils and spark plugs r in good order, ur tune is spot on and always use a quality filters (oil,air and fuel) always replacing them at required intervals (or a little sooner).
oh and dont carry around crap for no reason. always remember to keep weight as low as possible. depending on how bigger concern economy is u may want to stop using the drive thru window, u'll save fuel and wont get fat from junk food :)
Im using baldwon filters and i think repcos fuel filter. As for air filter im suing K&n drop in replacement filters which runs great with the car. Oil wise im using Castrol cos Ben from racpace wanted to use it. I personally like using Mobil synthetic. Im currently using Castrol 10w-70.
10W70 holy molasses batman !
yeah we are definately running thinner than that .. but I will check for sure.
now.. can someome educate me as to WHY the fuel filter could be causing poor consumption?
I am not saying that its not a valid possiblity but just want to know the reasoning behind it.
yeah I too am debating the S2 myth that it gets better economy.
we have an s2 and can just get 400k till the fill light comes on
we ( stagea owners ) might need to get a bit more methodical about what fix made what fuel econ difference. ( ie start logging it all in this thread etc )
also doesnt really seem like anyone in here has confirmed the working operation of their o2 sensors.
I am close to finally getting off my ass and getting my consult to see if it can read the operation of the o2 sensor while moving etc.
S2 here as well and am only getting 400kms before the light goes up which is around 60L (15L/100km). I would be far happier with 450kms (13.5L/100km) before light if possible. Running hi flow panel filter with TT mbc @ 10psi as the only mods. That's with Boost98 too.
I replaced the O2 sensor with the NGK/NTK one and when the car was in the workshop the other day they tested the O2 levels (or was it CO2?) to check air fuel mixture by sticking a rod into the exhaust connected to a handheld electrical meter thingy while driving around and all the readings were fine. Does that mean the O2 sensor is alright?
Been quoted $500 and for a custom 3" mild steel catback exhaust, very tempting if it guarantees drop of 1-2L/100kms.
Edited by webng
Well.. i now know the car runs exactly 419.5kms on a full tank of Boost98... the missus couldn't start it this evening as it had run out of petrol. It equates to 15-16L/100kms which in my books is still disgracefull seeing she uses the car 90% of the time and it'd be lucky to see more then 2psi. That was with a bottle of Nulon Injector cleaner in it too.
yeah thats pretty damned poor hey?
One thing I cant seem to get out of anyone are a few things
how many people can categorically say they have a working o2 sensor ?
Ie .. its been checked by reading fluctiating values from the sensor etc.
Another thing I want to know is what is the supposed fuel economy of the stagea
when it came out of the factory? Maybe it was woeful from the very begining and
we are just chasing our tails?
Another thing I want to know is what is the supposed fuel economy of the stagea when it came out of the factory? Maybe it was woeful from the very begining and
That's something that would be good to find out. Anyone here know the Stagea factory mileage?
ok....i have a page that i found i hope this helps a little
RS FOUR, PRODUCED FROM 1996 (SEPTEMBER)
-Fuel consumption l/100 = 12.9
RS FOUR, PRODUCED FROM 1997 (JANUARY)
-fuel consumption at 10-15 modes, l/100km = 12.9
25t RS FOUR, PRODUCED FROM 1997 (AUGUST)
-Fuel consumption at 10-15 modes, l/100km = 12.9
25RS FOUR, PRODUCED FROM 1997 (NOVEMBER)
-fuel consumption at 10-15 modes, l/100km = 12.1
25t RS FOUR V, PRODUCED FROM 1998 (AUGUST)
- Fuel consumption at 10-15 modes, l/100km= 11.3
25t RS FOUR S, produced from 1998 (august)
- Fuel consumption at 10-15 modes, l/100km = 10.6
25t RS FOUR V Produced from 2000 (june)
- Fuel consumption at 10-15 modes, l/100km =11.3
25t RS FOUR S, produced from 2000 (june)
- Fuel consumption at 10-15 modes, l/100km =10.6
25RRS FOUR, produced from 2001 (april)
- Fuel consumption at 10-15 modes, l/100km =11.1
Harrah!!!.... I own the most ecconomical stagea possible..... :no:
420-460 repeatedable around town/short freeway/hills
10.5L/100 has been done on the GOR/Otways/FWY
worse economey when i am just using it for general running around coz its all short trips with speed humps/roundabouts.
i've never seen any proof that a fuel filter can effect fuel economy. but its cheap insurance against leaning ur engine out.
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
