Leather R32 & Cefiro Gear & Hand Brake Boots Group Buy
Currently have a few extra sets from the previous group buy, PM me if you want one (no waiting time! pay and receive them next day)
I am running a R32 Gear & Hand Brake Boots group buy. (They also fit Cefiro's perfectly)
I have sourced a manufacturer in England that makes genuine leather Gear & Hand Brake Boots for R32 Skylines.
Nissan sells them for $150. He sells one gear and hand brake boot for $95 with postage to Australia.
But if we make a minimum of 10 orders, for $55 you will get a gear stick boot, a hand brake boot and express postage to your door.
If you are interested please PM me or post here to be included in this group buy.
New Group Buy (now taking payments)
Tristan21 (payment received)
Skyline32GTST (payment received)
superjet760 (payment received)
Toms32 (payment received)
bubbabooga (payment received)
Here is how to install the handbrake boot (all credit to Triptych for this installation guide and help, post number 204 on this thread)
For people having trouble installing the handbrake boot because they come flat not pre-bent this is what I did to fit it to my R32 GTS-T
1. Take old handbrake boot out.
2. Push leather inwards on old handbrake boot and sit the new boot on top.
3. You should now have the metal from the old boot and new boot sitting on top of each, Make sure it is lined up evenly.
4. Push the metal on the new boot at the same bend in the old boot so they are both bent at the same place.
5. Keep adding pressure to the metal on the new boot so after the bend it is touching the metal of the old boot.
6. Put them side to side to make sure they are bent in same place on the same angel etc, and fine tune as needed.
I know its a little hard to understand without pictures but seriously if you think about it, it is only a 2 minute job.
Here is how mine turned out (sorry about the bad apperture and focus on the steering wheel)
Edited by pablo101
  • Replies 373
Posted Images
So it's $55 for both leather boots? Cheap!
My PM isn't working mate, sorry. I'm interested if closing date is April 4th so put my name down :rofl:
Cheers.
the uk seller has them for $49 + $6 postage and only accepts credit card payments via paypal.
i'm not sure if these are the same ones as his, but I dont have pay pal or a credit card to buy from him
bLaQ.bOi is now on the list
just three more needed and we have our R32 group buy!!
payment is required when we have 10 people, I will PM everyone at that point
Edited by pablo101
WE HAVE OUR GROUP BUY PEOPLE :happy:
PM WITH MY BANK DETAILS HAVE BEEN SENT!!!
LEAVE ONLY YOUR SAU USER NAME WHEN MAKING BANK DEPOSIT!!
for those who missed out, PM me and if there is enough interest I will start another one
Edited by pablo101
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
