Good upgrade would be R32 GTR which are 16mm bigger
in dia and 2mm thicker along with braided brake lines and
good brake fluid and good brake pads.I would recommend
sloted rotors they have more bite do not get cross drilled
as they crack.Or I have heard that R33 GTS fronts are
also a suitable upgrade.The good thing about this upgrade
is that it's cheap and efective and still fit 16inch rims.
yeah, 32 GTR would be the go. they are cheap enough as lots of GTR owners go for bigger brakes. they run a 296mmX32mm front rotor vs the 280X30 you have now, and the rears are 297mm so maybe do all 4 at once.
Quote me if I'm wrong but I think the rear brakes are they same on
GTR-GTS (GTR non Vspec)
Nothing wrong with standard M Spec brakes for track days, as long as they are in good condition. The usual
Replace the standard rubber hoses with braided
Service the callipers
DBA 4000 series slotted rotors front (4909) and rear (4908)
Castrol Super Response Dot 4 brake fluid
Hawke Black or (if you have ABS) Hawke Blue MT 4 compound pads
:pirate: cheers :)
:) cheers :(
wouldn't u be better off buying new DBA 'gtr' slotted rotors if your going to buy new ones? Surely the price would be similair!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
