lol yea flashing greenish color. but in the manual it says that relates to error codes?!?!?!
my knock sensor doesnt read, but this is only on starting, will it only register once engine running?
It will only show actual real time knocking, so if it aint knocking it wont show.
and my water temp C NS_WT-1 reads about 70-80c, and when i switched the jumper it reads -16 or something, which is correct?
70-80 whilst running or stationary and cold? if it says 70-80 when cold then it is wired wrong.
  • Replies 765
I want to clear some things once and for all.
Some guys running EMU on sr20det experience some rich idle a/frs, fuel cuts.
Some guy on emanage forums, said that moving the jumper 8 from 1-2(default greddy) to 2-3 cured his problem.
Its the jumper for the ignition output signal. Greddy Default is 5v(jumper set to 1-2) and jumper set to 2-3 makes it 12v.
So can someone pls confirm: what configuration should rb20/rb25/rb25neo/rb26 guys run ?
Reading the EMU faq I thought rb2neo guys benefit from going to 12v ignition output signal.
Thanks in advance!
Edited by robots
^^^^^ sorry in my first post in this forum i mentioned that all cars should be run (jp 8 2-3 ) 12v.... sorry i did not mention it :ninja: i assumed you had already done that.
if you want more info see first post.
So I should set the jumper 8 to 2-3 and it will help you reckon ? ))) Haha. I feel kinda happy again ))
Thanks!
Yeah definately, jumper 8 set at 2-3 bypasses an ignition circuit inside the emanage.
Even though it is 5v / 12v jumper it cannot jump the 5v signal to 12v.... whatever voltage goes in can only ever come out the same voltage. The issue arises with some cars that have "dirty" signals, these signals are further modified by the 5v circuit and can play up causing misfires and so forth.
I set ALL emanage ultimates up at 2-3 (JP8) and work from there, i have NEVER had an ignitor failure in over 40-60 installs. (this info is based on a conversation i had with ichida-san who designed the EMU)
hey guys. just wanted to know what to set my knock sensor to.,
uras, or whover.
how do i set it up.
atm the jumper for it is set to 1-2. and in parameters im using the air intake temp/knock sensor 2 with it set to resonate and 7.02.
is this cool??
^^^^^^^ no one knows?
also i REALLY NEED a good tuner of a emu in the sunshine coast/brissie area.
can anyone recommend anyone, and how long and much will it be?
Hi Guys,
My EMU was installed & tuned by a workshop, but the guy who did the work is away at the moment.
1st time I connected my laptop to the EMU, I spotted a huge error log. Any ideas?
my car is an R34 GTT (manual).
[2008/01/26-15:19:09]------------------------
65504:0443-0006[incorrect 3CH ignition input signal]
65505:0444-0003[incorrect 4CH ignition input signal]
65506:0445-0001[incorrect 5CH ignition input signal]
65507:0446-0002[incorrect 6CH ignition input signal]
65508:0441-0004[incorrect 1CH ignition input signal]
65509:0442-0005[incorrect 2CH ignition input signal]
65510:0443-0006[incorrect 3CH ignition input signal]
65511:0444-0003[incorrect 4CH ignition input signal]
65512:0445-0001[incorrect 5CH ignition input signal]
65513:0446-0002[incorrect 6CH ignition input signal]
65514:0441-0004[incorrect 1CH ignition input signal]
65515:0442-0005[incorrect 2CH ignition input signal]
65516:0443-0006[incorrect 3CH ignition input signal]
65517:0444-0003[incorrect 4CH ignition input signal]
65518:0445-0001[incorrect 5CH ignition input signal]
65519:0446-0002[incorrect 6CH ignition input signal]
I had a look at some of the wiring today (before I ran out of daylight)
The Ign Input Ch1, 2 and 3 looked to be wired correctly (according to the EMU wiring instructions)
I did find about 6 wires that weren't connected, but they didn't seem to be related to the ignition.
I look some photos so I could go back and double check... still scratching my head!
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
