lol yea flashing greenish color. but in the manual it says that relates to error codes?!?!?!
my knock sensor doesnt read, but this is only on starting, will it only register once engine running?
It will only show actual real time knocking, so if it aint knocking it wont show.
and my water temp C NS_WT-1 reads about 70-80c, and when i switched the jumper it reads -16 or something, which is correct?
70-80 whilst running or stationary and cold? if it says 70-80 when cold then it is wired wrong.
  • Replies 765
I want to clear some things once and for all.
Some guys running EMU on sr20det experience some rich idle a/frs, fuel cuts.
Some guy on emanage forums, said that moving the jumper 8 from 1-2(default greddy) to 2-3 cured his problem.
Its the jumper for the ignition output signal. Greddy Default is 5v(jumper set to 1-2) and jumper set to 2-3 makes it 12v.
So can someone pls confirm: what configuration should rb20/rb25/rb25neo/rb26 guys run ?
Reading the EMU faq I thought rb2neo guys benefit from going to 12v ignition output signal.
Thanks in advance!
Edited by robots
^^^^^ sorry in my first post in this forum i mentioned that all cars should be run (jp 8 2-3 ) 12v.... sorry i did not mention it :ninja: i assumed you had already done that.
if you want more info see first post.
So I should set the jumper 8 to 2-3 and it will help you reckon ? ))) Haha. I feel kinda happy again ))
Thanks!
Yeah definately, jumper 8 set at 2-3 bypasses an ignition circuit inside the emanage.
Even though it is 5v / 12v jumper it cannot jump the 5v signal to 12v.... whatever voltage goes in can only ever come out the same voltage. The issue arises with some cars that have "dirty" signals, these signals are further modified by the 5v circuit and can play up causing misfires and so forth.
I set ALL emanage ultimates up at 2-3 (JP8) and work from there, i have NEVER had an ignitor failure in over 40-60 installs. (this info is based on a conversation i had with ichida-san who designed the EMU)
hey guys. just wanted to know what to set my knock sensor to.,
uras, or whover.
how do i set it up.
atm the jumper for it is set to 1-2. and in parameters im using the air intake temp/knock sensor 2 with it set to resonate and 7.02.
is this cool??
^^^^^^^ no one knows?
also i REALLY NEED a good tuner of a emu in the sunshine coast/brissie area.
can anyone recommend anyone, and how long and much will it be?
Hi Guys,
My EMU was installed & tuned by a workshop, but the guy who did the work is away at the moment.
1st time I connected my laptop to the EMU, I spotted a huge error log. Any ideas?
my car is an R34 GTT (manual).
[2008/01/26-15:19:09]------------------------
65504:0443-0006[incorrect 3CH ignition input signal]
65505:0444-0003[incorrect 4CH ignition input signal]
65506:0445-0001[incorrect 5CH ignition input signal]
65507:0446-0002[incorrect 6CH ignition input signal]
65508:0441-0004[incorrect 1CH ignition input signal]
65509:0442-0005[incorrect 2CH ignition input signal]
65510:0443-0006[incorrect 3CH ignition input signal]
65511:0444-0003[incorrect 4CH ignition input signal]
65512:0445-0001[incorrect 5CH ignition input signal]
65513:0446-0002[incorrect 6CH ignition input signal]
65514:0441-0004[incorrect 1CH ignition input signal]
65515:0442-0005[incorrect 2CH ignition input signal]
65516:0443-0006[incorrect 3CH ignition input signal]
65517:0444-0003[incorrect 4CH ignition input signal]
65518:0445-0001[incorrect 5CH ignition input signal]
65519:0446-0002[incorrect 6CH ignition input signal]
I had a look at some of the wiring today (before I ran out of daylight)
The Ign Input Ch1, 2 and 3 looked to be wired correctly (according to the EMU wiring instructions)
I did find about 6 wires that weren't connected, but they didn't seem to be related to the ignition.
I look some photos so I could go back and double check... still scratching my head!
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
